hi i rooted the torque converter in my auto box in my 32 the other day and decided that it was time for a manual, so i brought a half cut. i also got given 6 liters of hot house green auto paint and four litres of clear. then i got to thinking, i have an old merc 280sl 1967 model down in the shed and then it struck me PROJECT!!!!. So im going to put the spare rb20 in the merc with the auto box and a new torque converter then paint it hot house green. if anyone has any sujjestions ideas or comments on the convertion painting or anything related (like you think its a gay idea and i should find something better to do with my time) your posts would be much apreciated.
https://www.sau.com.au/forums/topic/89646-mercedese-benz-rb20-conversion/
Hey fReak32,what sort of literage of paint is required to paint the whole car?
What kind of paint is it,and what kind of gun do you use for the job.:D
I am trying to collect some information of painting because i am going to try my hand at it.
It would be a good conversion with the paint to match.Ive seen an old merc with a 13b turbo rotary engine in it.Yours will be that much more different.You could even get an article going on here or in a magazine at the completion as being ''probably'' the first RB20det merc in the country if not the world. B)
Edited by Trust33
you should be able to paint a car with about five ltrs. i use acrylic laquer as its much more forgiving than 2 pack, with acrylic you will need the paint and about the same again of clear gloss then you need primer surfacer. i use a scorpion gravityfed gun and i have used cheap guns before and not been able to tell any diference, although i am only a hobbiest painter, not a pro.
Its school holidays, obviously, so ignore the above.
Go easy mate, it was a joke! Steele and I are friends he really just wanted a reply to his thread. :D
I guess the reason he chose the RB20DET is because he has a spare one laying around, the paint was free.. Should turn out to be a cheap conversion in the end!
Sounds good.
Keep us posted!
So where are you from?
Edited by Trust33
def post pics! the engine conversion will be awesom. No need for rb25 or 30, compare the power of the rb20 to the stock 2.8 and you'll see the rb will be great.
the ol pagoda roof 280 6cyl makes ~170hp compared to the ~215hp RB20det (not to mention easy mods from exhaust etc). The merc weighs not much more than a 32 skyline also.
not sure about the hot house green tho! get the engine in it and running before you go painting it green!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
