Some of the race guys in our club use acetone to boost octane rating in their turbo cars. Seems to work fine. Never seen an engine suffer because of it. Its a lot cheaper than manufactured octane booster And be buggered if I can catch them!
But there is a risk in everything eh?
Cheers
Bov
yea i have been looking at acetone for a while too, i think they are right and it would be safe, becuse its only like 90mls to every 40lts, i mean there is more shit in fuel than that.... after reading that web site i think i might try it... f**k it its only an RB20 haha cheap!
Edited by meep
well i'm gonna give it a go. read the full site adn it seems to make sense :P. bought some fuel yesterday without acetone and will try acetone next tank. will also note down how many k's and it's response. anyone else want to be test dummies.?
would be good to get an overall concensus
nOOSE
i bought 1lt yesterday from k-mart $11, will try it soon, just doing a bit more reading.
it is one of the chemicals in nail polish remover.
i dont think it would damage anthing it's only 30mls to every 40lts, plus it is only a glass and metal cleaner... so... ill give it a shot.
Hmm I think I will give this a go, will head down to K-mart and put some in when I fill up next to see if it improves on economy. So you just add it like an octane booster? They say to use 2.5ml per Litre... so for my 55L that's like 140ml per tank.
Edited by Lithius
Read this post yesterday,
had some acetone where I work as a lab technician, prior to this done some reasearch and found a few sites with an emphasis on racing recom 5% by volume. Acetone 100ml/L (pure analytical grade) 1L added to 20 odd L of prem. Very happy, can't wait to leave work and get back in the line.
Is there an acetone craze going on...? I went to 5 different stores, and each had the label for acetone and a price but all were out of stock! at one place there was a little 500ml bottle and i picked it up and thought "narh there'll be a bigger one here somewhere" - the guy next to me swipes it and says "hope you weren't planning on buying that" then he giggled merrily to himself and proceeded to the checkout.
Managed to get the last one available at bunnings although I had to settle for a 4L tin for $28.99
my excel had a bit under 1/4 tank and i put 355ml (a beer bottle) of acetone in. drove around stop start, left to right. temp stayed normal, no miss, no post ignition. everything stayed the same, it might have gone a little bit better mid range, but cant swear on that, anyway it done no damage at all and ill be interested to see if any of you guys get good results.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
