I put a HKS SSQV on my car on monday, and since then it stalls sometimes without warning it jsut shuts down, when i try start it it fire first time....
Any idea guys, its pretty bad its done it a couple times when clutching around a corner
Cheers guys
https://www.sau.com.au/forums/topic/89989-rendom-stalls-r32-gtst/
mmm yeah its your bov thats doing it
let me guess... you'll boost upto the corner and then clutch in and cruise round the corner with your clutch in... car stalls mid corner and you allmost loose all your steering :D
hehe yeah thats what happens with stock ecu's and sensitive afms and atmo bov's
try stiffening up the spring in the bov alot and plumbing it somewhere else and running the stock bov
-Ruffels
Edited by Ruffels
lol i did it in the first time because theres a cop shop on the corner, and it stalled coming into the corner... and i almost went into the cop show the steerings that heavy... does anyone know how to tighten the spring in the hks ssqv up all the way?
it wont help at all. If you dont want it to stall put the stock one back on. The spring will do jack shit because no air is getting plubed back and comfusing the computer. Why bother to even buy an SAFC and spend money on a noise...
Yea tru... but i am doing full internals shortly... and winding up the boost to 20psi, so i want all the gagets to looks after every thing plus $200 for a new SAFC it will be a good $200 spent for the short term
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
