Looking around for a manifold at the moment. Someone mentioned having a look at the ones on the justjap site. Never heard anything about them so I was just wondering if people around here have used them and what they thought of the quality. Or are these like those ebay ones you see all over the place?
I have asked for the pipe wall thickness and some pics of inside the collecteor as this pic doesn't really show me much.
https://www.sau.com.au/forums/topic/90539-justjap-exh-manifolds/
I brought my car and heaps of stuff off them. Darron and Tony will always help you with things you need for your car . Justjap carry a large supply of new and used parts.
I Purchased one of these off ebay. The one i got looks exactly the same as this unit - same design etc..
Issues that i have had so far -
1: The flange that the turbo bolts onto had to be chopped off and welded back on in a different angle as the exaust housing was hitting the head when i tried to bolt on the GT3540 turbo
2: there was excess dags and welding waste in the pipes - 2 big pieces of metel fell of as soon as we hit it with a dy grinder which would have destroyed my turbo straight away.
3: one of the middle studs had to be cut to half length because it hits the middle runner
4: if you look close you can see that number 6 would run really close to the firewall and it does - you can barely fit a 2.5" dump between the firewall and the pipes and you would have to bend it over closer to the side of the car which in my case R33 it will be close to the ABS pipes and we dont think we can fit a 3" pipe through there because there is air conditioner gear there also.
5: All the surfaces had to be machined.
6: The studs that bolt the turbo were not staight and we had to bash them into place because the turbo wouldnt even bolt on properly.
We spent 10 hours on the manifold - starting to wish i spent the extra $600 and got something that did not need soo much time and effort.
Not 100% sure these are the SAME manifold but it is definatly the same design as the one I have. Here is a url to check out some pics.
CLICKY ME NOW FOR PICS
Edited by Guilt-Toy
are you sure this is the same as the ebay ones as the ebay ones look to be a different design to me... they only have a single pipe from the collecter for the wastegate, where as this has 2 pipes from the collecter merging into one. pipes merge into collecter differently
they have a 2 bolt flange for wastegate, where as this has 4
the overall pipe shape is different on one of these 2 an ebay one.
these are the ebay ones i'm talking about and haven't seen ones that look like the one I displayed yetb3_1_b.JPG
Edited by r32boy
Guilt Toy: In the interests of avoiding confusion, and considering you didnt buy your manifold from Just Jap nor can you be sure of what you are saying, please edit your post, the manifold you are referring to is one of the ultra cheap poor quality manifolds floating about on ebay, and clearly not the same as the high quality units Just Jap are selling.
The manifold does look very very similar. I was sure they are the same design because they look the same. I know mine is a cheapie from ebay which is why it needed soo much fixing and im sure the one from Just Jap does not need any cleaning or modding to fit properly. That was my experience with them.
there is many differences, they are not that similar.
Edited by r32boy
Just to let you know that i bought a manifold for my RB26 from GCG Turbos that looks EXACTLY the same as the 'two into one' wastegate pipe one pictured above. It cost me $600 i think and is of excellent quality; 304 grade stainless, almost 3mm thick too. The only difference is that mine had no wastegate flange so i could put a Tial item on. It had a T4 flange so i bought a T4 to T3 adapter which was $100 and is CNC machined.
I havent finnished my build yet, so i cant tell you how it performs, but a fabricator i trust said that its of excellent quality and he cant believe i got it for that price. He said i wont have any sagging problems, but i braced it just in case.
If the Just Jap ones are the same, theyll be good quality. Maybe drop into GCG and compare.
If you do a search in the Forced induction section under "What do you think of my high mount turbo set up?" (or something like that), you should find a few pictures of my manifold on my engine.
Shaun.
PS How much are the Just Jap ones?
cheers for the reply shaun, they are $550 which is why i'm interested, but if they are not good quality i'd rather spend $900, I hate shitty parts. But I am starting to run low on funds for the car so thats why i'm looking around at ready made manifolds.
Hopefully they can supply me with collector pics and some more info as the site doesn't list a damn thing
Edited by r32boy
As long as theyre thick walled and made out of good stainless they will be fine. The welds look awesome so i cant imagine that the collector would be full of dags or anything.
Im like you; i hate shitty parts and i didnt want to spend 15 grand on an engine and turbo and have a shit manifold, so i spent heaps of time looking around and eventually settled on one that looks extremely similar to the one you showed. Ill try to get a pic of mine up here so you can see.
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1680, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
