Looking around for a manifold at the moment. Someone mentioned having a look at the ones on the justjap site. Never heard anything about them so I was just wondering if people around here have used them and what they thought of the quality. Or are these like those ebay ones you see all over the place?
I have asked for the pipe wall thickness and some pics of inside the collecteor as this pic doesn't really show me much.
https://www.sau.com.au/forums/topic/90539-justjap-exh-manifolds/
I brought my car and heaps of stuff off them. Darron and Tony will always help you with things you need for your car . Justjap carry a large supply of new and used parts.
I Purchased one of these off ebay. The one i got looks exactly the same as this unit - same design etc..
Issues that i have had so far -
1: The flange that the turbo bolts onto had to be chopped off and welded back on in a different angle as the exaust housing was hitting the head when i tried to bolt on the GT3540 turbo
2: there was excess dags and welding waste in the pipes - 2 big pieces of metel fell of as soon as we hit it with a dy grinder which would have destroyed my turbo straight away.
3: one of the middle studs had to be cut to half length because it hits the middle runner
4: if you look close you can see that number 6 would run really close to the firewall and it does - you can barely fit a 2.5" dump between the firewall and the pipes and you would have to bend it over closer to the side of the car which in my case R33 it will be close to the ABS pipes and we dont think we can fit a 3" pipe through there because there is air conditioner gear there also.
5: All the surfaces had to be machined.
6: The studs that bolt the turbo were not staight and we had to bash them into place because the turbo wouldnt even bolt on properly.
We spent 10 hours on the manifold - starting to wish i spent the extra $600 and got something that did not need soo much time and effort.
Not 100% sure these are the SAME manifold but it is definatly the same design as the one I have. Here is a url to check out some pics.
CLICKY ME NOW FOR PICS
Edited by Guilt-Toy
are you sure this is the same as the ebay ones as the ebay ones look to be a different design to me... they only have a single pipe from the collecter for the wastegate, where as this has 2 pipes from the collecter merging into one. pipes merge into collecter differently
they have a 2 bolt flange for wastegate, where as this has 4
the overall pipe shape is different on one of these 2 an ebay one.
these are the ebay ones i'm talking about and haven't seen ones that look like the one I displayed yetb3_1_b.JPG
Edited by r32boy
Guilt Toy: In the interests of avoiding confusion, and considering you didnt buy your manifold from Just Jap nor can you be sure of what you are saying, please edit your post, the manifold you are referring to is one of the ultra cheap poor quality manifolds floating about on ebay, and clearly not the same as the high quality units Just Jap are selling.
The manifold does look very very similar. I was sure they are the same design because they look the same. I know mine is a cheapie from ebay which is why it needed soo much fixing and im sure the one from Just Jap does not need any cleaning or modding to fit properly. That was my experience with them.
there is many differences, they are not that similar.
Edited by r32boy
Just to let you know that i bought a manifold for my RB26 from GCG Turbos that looks EXACTLY the same as the 'two into one' wastegate pipe one pictured above. It cost me $600 i think and is of excellent quality; 304 grade stainless, almost 3mm thick too. The only difference is that mine had no wastegate flange so i could put a Tial item on. It had a T4 flange so i bought a T4 to T3 adapter which was $100 and is CNC machined.
I havent finnished my build yet, so i cant tell you how it performs, but a fabricator i trust said that its of excellent quality and he cant believe i got it for that price. He said i wont have any sagging problems, but i braced it just in case.
If the Just Jap ones are the same, theyll be good quality. Maybe drop into GCG and compare.
If you do a search in the Forced induction section under "What do you think of my high mount turbo set up?" (or something like that), you should find a few pictures of my manifold on my engine.
Shaun.
PS How much are the Just Jap ones?
cheers for the reply shaun, they are $550 which is why i'm interested, but if they are not good quality i'd rather spend $900, I hate shitty parts. But I am starting to run low on funds for the car so thats why i'm looking around at ready made manifolds.
Hopefully they can supply me with collector pics and some more info as the site doesn't list a damn thing
Edited by r32boy
As long as theyre thick walled and made out of good stainless they will be fine. The welds look awesome so i cant imagine that the collector would be full of dags or anything.
Im like you; i hate shitty parts and i didnt want to spend 15 grand on an engine and turbo and have a shit manifold, so i spent heaps of time looking around and eventually settled on one that looks extremely similar to the one you showed. Ill try to get a pic of mine up here so you can see.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
