hey guys im looking at a 33 gtr, im just wondering, whats the build quality like in these cars? are they solid?
also are they reliable? do they require much maintenence? do they need much work if theyre near standard (ecu, exhaust, filter)
what are some common problems in r33 gtr's?
also what do you think is the best way to buy? imported or buy from someone private?
how does the r33 drive? is a good street car? can it go one track? how does it compare to say an evo 7?
cheers
Build quality is good. The RB is very strong and mod friendly.
Reliable depends how well maintainted it is and how far you push it. its a sliding scale.
if its near standard doens't need much more work than any other car. oil changes every 5,000ks with good oil etc....
Common problems, dont really know... make sure you get a compression/leakdown test before buying... don't pay any attention to km's on the clock most imports have been wound back.
Would you feel comfortable blowing ~40k on a car you've never seen or driven? i know i wouldn't, i'd prefer to buy local first, but if you can't find what you're after local you could look to import...
I drive my R33 GTR to work daily and track it on club track days without changing anything, drive on track, race drive home etc... but mine is pretty standard...
evo7 never driven one can't say sorry.
To give you some idea, stage 1 mods on a GTR includes exaust/cam gears/ecu/more boost on std turbos and you'll make about 250rwkw.
i would say the gts-t is a much better street car than the gtr
The gtr is more of a track car. It is laggier in stock form than the gts-t is.
The evo 7 is a much newer car and you will probably find them to be in better condition than the r33 gtr
Build quality RB26DETTs are great engines. The only downfall with the GTRs are maybe the maintainence costs. You got 2 turbos to look out for. It is an AWD so many more moving mechanisms?
Near stock standard they are really fast enough. Zorst, ECU, injectors, up boost and you can go pretty damn fast.
If it is a daily, then you might need to look out for fuel consumption. They take quite a bit of fuel.
Not many GTRs that are for sale now therefore choices are minimal. You can try importing one :D
I was under the impression that if you were too Import a car it would be considerably Cheaper than buying one in Australia.
Aka - 40k for a 33 GTR in AuS
-20-30k For a 33 GTR from Japan
Obviously you flip a coin to see if you get a good one or a Lemon from Japan but am I wrong about pricing?
ive been doing alot of hunting, it seems imports are alot cheaper, so i guess this just means we need a broker that can be trusted, and looks at the car over there inside out and maybe even does mecanical tests? is there such thing? i think imports101 does something like this, anyone else?
GEARBOX SYNCHROS.......the 33 GTR seems to eat synchros, you probably won't notice it on a test drive as it only seems to occur once the gearbox is very hot (and believe me it gets fooking hot, girlfriend thought I kept leaving the heater on), the upside is that it heats your drafty garage :P You will likely notice the gears crunching from 3rd to 4th or 4th to 5th. There is a temporary fix which involves using Redline Heavy Shockproof gear oil but ultimatley you'd need to have the gearbox out and replace synchros (they're only a couple of hundred bucks but it's the labour that kills). Other than that watch out for fake V Spec's and very standard cars as they're sometimes ex raced ones that have had standard bits put back in. Don't let these things put you off though, I've had mine for 10 months now and I absolutely love it, it only cost as much to run as you want new shiny go faster bits!! I'm addicted to modification so spend all my expendable income on it....with no regrets :)
G'day mate,
I found this stock '96 HR33 GTR V-Spec down in Sydney, pretty good price compared to what I've seen around, thought it might interest you if you're looking at buying one locally (I was going to but my loan requires the car to be 8 years or younger :rolleyes:).
Click here
Question, does anyone know the kw of a stock HR33 GTR? Or of all Skyline models?
Cheers.
Edited by SHT HOT
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
    • Wife and I are still looking for a new home. One condition was a large enough garage for a full-size lift in one bay. Now if only we could find something... We've been looking for almost a year now.
    • Thanks everyone for the ideas! Sadly, ramps are a no go for me. With young kids at home, I do most of my work late at night while they're sleeping. Starting the car multiple times wouldn't be a great idea.  I'll go see one of those new long reach low profile jacks and take a couple measurements to see if they will fit.
