Like topic says i got my car back today and it made 347hp at 15psi and timing 13 with ITS T-57 turbo, making fullboost at 3500rpm and peak torque at 4500rpm holding it all the way through rev range...car has top mount maniflold and tial 38mm external wastegate and is "bit" too loud when on boost...its got wolf3d aftermarket computer and now problem is unsteady idle and around 1000-1100rpm, and when changing gears car doesnt pick up revs straight away, could it be related to greddy type rs bov though it shouldnt matter with wolf running the car...???
https://www.sau.com.au/forums/topic/91171-got-my-car-today-347hp-atw/
Are you still running a AFM or Map sensor? cause if your running an AFM its recommended you use a plum-back BOV otherwise when the pressure is released into the atmosphere the ECU will think theres a loss of Oxygen therefore increases the fuel hence flooding the motor... have a look at the GFB (Go Fast Bits) Stealth... i have seen them run upto 25psi in skylines and you can adjust how much you want to vent into the atmosphere and how much you want to plum-back into the manifold...
Hope this helps...
Regards,
Sarkis
Edited by QRI05E
This car came in with a new turbo and Idled like this even with the stock ECU,It had a leak down test and all the normal stuff like injector clean and test,cam timing ,vac leaks checked out etc and still idles like the cam is very advanced but made more HP than we wanted even running at 1bar.We will look into it further next week.Thinking the VVT hub is faulty.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
