Well I have decided to sell the R33 at the end of the year, because I'll be looking to buy a house.
Just letting everyone know in advance, incase they are after parts, I will be taking the car back to stock as modded cars are too hard to sell for what they are worth.
Parts that will be available are as follows:
Z32 AFM & Plug
HKS GTRS Turbo
Nismo 550cc Injectors
3" JJR Bellmouth Front/Dump pipe
Kakimoto Regu 06&R Cat Back
Apexi PowerFC with Commander and Electronic Boost Controller
Splitfire Coilpacks
Nismo Fuel Pump
Cold Air Box
HICAS Lockbar
Will post up closer to these parts being available. Just giving a heads up, as I know what it's like when you buy brand new parts and the next week good second hand parts become available.
Start saving! :down:
31's driveable and seeing the odd short trip, lots of little jobs left though. Like paint/fit front bar, lip, roll and paint both rear quarters and paint both front guards; pull leaking front pipe off and get welded up ('perfect condition' secondhand BATMBL dump I bought for a fair amount of dough leaked from the word go around the wastegate pipe...), wheel align, solid subframe and diff mounts, and proper tune.
But it goes, skids and sounds angry, haha.
SO in other words look out the streets of Hobart :)
Picked up my new 040 from SPG last week so all that leaves is tuning of the blue bucket :)
Well, rear subframe bushes let go, ordered some new ones but got sent wrong ones.
Made some phonecalls and was told Nolathane were outta stock till mid July. Now I am told its mid August...
So I decided to pull the front end apart and replace the LHF Inner Driveshaft boot. Easy enough job, except nobody has a boot that fits... Spose my local Nissan dealer will tell me they are about $90 each and 4 weeks outta Japan next for a genuine one.
So the GTR is sitten on stands with bits missing everywhere and the Baskerville Hillclimb is on in three weeks. This will be pushin it to get everything here and done by then.
Dude that is F'n harsh!
What about the RB25 thats for sale??
Didn't want to go RB25 as none of my parts (cams, gears, injectors etc) would fit, would need a new ecu and turbo not ideal either.
I know the feeling, i order some gear for the FC from Rare Spares and they sent me the wrong items, when i rang to let them know they informed me that they didn't have what i needed instock and that it would be 12 weeks before they would have what i needed :rolleyes:
well, my mate fixed my powerfc so kermit is back in action! hoping to enter basky hillclimb too which should be fun :)
Glad to hear its all sorted, lets hope nothing else happens now :bunny:
Well thankfully I managed to fit the aftermarket boot to the driveshaft. Looks like it will work for now.
So as long as I can either get the bushes from Nolathane or temp up some "pineapples" I should be good for the Basky Hillclimb yet again.
The race is on, i have to remove old engine and put on stand to remove cams, injectors, gears and covers. Tidy up engine bay whilst its out and then when new engine arrives fit cams, injectors, gears and covers before dropping that back in.
Have to fit 040, new seat/harness and harness tabs and then tune it so i can make the hill climb :(
Racin before the event and all... thats competitive.
Well I just selected another gear, bush kit arrived and was the correct one this time.
Just arranged shed space, as mine is full at the moment, for this Saturday to fit em all up.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
