what date is the baskerville hill climb? its not that cove hill route is it..?
mite grab some new tires and come along.
Only thing is, looking into my crystal ball, just now, its looky cloudy.... wait.. RAIN lol
whats the requirements for the tas hill climb series?
ie, licences etc and car requiremnets. Usual stuff like tow hook marking, battery marker? and or kill switch?
Just wanna know whats involved before I lay down coin on tires etc
good helmet, cams 2s license (which goes hand in hand with a CAMS approved club) fire extinguisher , battery sticker thats about it lol they usually recommend secondary bonnet restraint but at CV i was just using normal latch ones. if i dont run basky HC (which is looking like im not atm with the cars issues ) you can borrow my helmet jack :blush:
Edited by Funz
Blue 150mm sided triangle to mark battery location
Metal Valve caps
No fluid leaks
Fire Extinguisher with Metal Bracket
Helmet that meets AS1698-74
Good seatbelts (Not UV damaged or frayed)
Good throttle return spring/mechanism
Treaded tryes. ie: if they bald to start with then no run.
I could go on but they are the basics.
and yes I did do all the relevant training and assessment's to be a CAMS Scrutineer, just waiting on the Licence to arrive in the mail. :blush:
arh good well all thats a check. I'm a current member of HSCC just gotta work out the 2S or 2NS licence or whatever.
oh and re the helmet, thanks adam, but all sorted. cheers
Edited by Mr. Untouchable
Well, took three days in the end but...
Entire rear end has been removed, subframe bushes all pressed out and new Nolathane bushes fitted in their place and got back on the road Monday night.
I have to say that for such a small change, 4 bushes, its made such a difference to the way the car reacts and drives.
Bring on Basky I say, enry went in the mail today, scrutineering tomorrow.
just got my 33gtst back, made 270rwkw on a steady 15pound, do another 1000k's then re-tune at Advan in sydney and run 25pound. hoping to get over 330rwkw. and building a 3L t51r SPL motor hopefully going into a 34gtr. got the bottom end and turbo. YAY!
Sounds like your alot closer than me PJ, my engine hasn't even turned up yet so looks like i wont be making Basky at this stage :banana:
It has given me plenty of time to clean up a few other things with the car though but this weather is killing me with no garage to work in ;)
