What clutch did you go with??
I just fitted an Xtreme Motorsports DSBMS Clutch Kit
Had big shudder issues when first fitted but appear to have eased a bit. Reverse is a killer still though.
Not sure but I think the fact its AWD doesn't help much, if you dump the clutch a bit harder it feels like the front diff is trying to climb out from under the car now.
I have spoken with Xtreme about this and we are working on a solution.
Be good to see how it copes come the Highclere Hillclimb next weekend. :bunny:
im just hoping my car is gonna survive highclere :-P
Highclere isn't that hard on cars.
Its all go except for one corner in the middle.
Basky Hillclimb probably puts more strain on your car than Highclere ever will.
aah nice! i need to find some vids of the highclere run so i know what it looks like
its going to rain. give me a call if you need me to reconstruct your car lol.
send me a msg if you head out mate I need a few laps round there as well
well. im hoping its an early or late drizzle! i want a few laps. ill be heading out there anyways even if i dont run :)
fark that off. seems your going for a "race car look" but your going about it wrong mate
put your GTR wing back on, get a GTR replica bar on the front and ditch the rear bar for a stocker. you could go with rear over fenders and even wider front guards but you could still pull it off as it sits
maybe a replica paint job like this....
I can get the decals/sponsors made and could get your wheels sand blasted and could paint them white also. not to mention i'm pretty handy with my tig i could even replicate that side pipe.
problem is... i dont really want the GTR look.. which is why im eventually gonna remove gtr bonnet, get rid of gtr wing and grill too.
I like the big wing look :nyaanyaa: have always wanted one, granted people arent gonna like it, but in the end its my car :-) i wanna do some tests with the wing at a track day as its adjustable. and hey, if it proves useless at a point i can take it off, whack it on cheries car when she gets a skyline :-P
I like the big wing look :) have always wanted one, granted people arent gonna like it, but in the end its my car :-) i wanna do some tests with the wing at a track day as its adjustable. and hey, if it proves useless at a point i can take it off, whack it on cheries car when she gets a skyline :-P
Oh it wont be totally useless, when you get all hot and bothered from wrestling the car whilst its behaving like a cop on the track you have somewhere to hang your race suit out to dry :nyaanyaa:
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
