  • 3 weeks later...
Well my 32 GTR is on the hoist, and about to under go a full overhaul
new motor is built, just a set of CP forged piston's and some Nismo rod's, Tomei sump baffle, Kelford cam's, OS giken cam gear's,
OS giken twin plate clutch and moly flywheel, still need to decide ona fuel rail and injector size
Have removed engine and box, also complete front suspention and x-member, and have stripped to engine bay of everything,
and it's in bare metal ready for a little bit of seam welding here and there, then it's paint time have picked a colour but i not letting
the cat out of the bag on that one....:rolleyes:
here are a few pic's,
post-70098-0-82268400-1299374953_thumb.jpgpost-70098-0-15321200-1299374972_thumb.jpgpost-70098-0-94182900-1299374981_thumb.jpgpost-70098-0-51070500-1299375042_thumb.jpgpost-70098-0-15163300-1299375128_thumb.jpgpost-70098-0-47154900-1299375142_thumb.jpgpost-70098-0-01741000-1299375156_thumb.jpg
Hey zoidbergmerc yeah its a 26 out of a 94 model Vspec1 but it had the longer crank in it and i just got a basic budget reco (as budget as you can anyway) but its basically got Ross forged pistons, nitto rods, ACL bearings, oil restrictors, external oil drain, hi octane sump extension, basic head reco with heavy duty valve springs for poncams later on etc. Really just a full refresh with no heavy machining or over the top parts. I figured if i went all out on it and something went wrong then i would'nt have the money to do it again so i just tried to get away with as much as possible while fixing the factory probs and making it more reliable. I mean nissan knew what they were doing and stock these engines are capable of decent power so with a few new bits it should do what i want for as long as i want well hopefully anyway lol. I would get some pics up but im really struggling to do that ive got them off my iphone and onto picasa3 but i cant seem to get them onto SAU so if anyones got any tips they'd be much appreciated.
Hey mate, where did u get ur engine work done? Wot power r u hoping to make? And wot fuel system r u running?
Hey I pulled the engine out myself but my mate works at Tas Engine Reco in Hobart so they did all the work. I'm putting Garrett -5s on it so I'm hoping for around 340-380kw obviously closer to 380 would be better lol but I guess it all depends on the tuner it should be good for 400 in theory but you know how things vary. As for fuel system I haven't got anything sorted out yet but I have removed all my hicas stuff apart from the hard lines from the front to back and I've heard something about converting them to fuel feed lines cause they're bigger than the factory ones or something like that but I'll work it out. Other than that just a decent intank feeding a surge tank with an external feeding the injectors havent looked at any brands yet. My mate got I think it's siemens injectors in a kit with a rail reg and lines pretty cheap through his work on his 25 and they seem to do the job well. So I'll probably go with those. But really at the moment just a saving game lol. It's true GTR owners are all poor aren't they lol.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
