Well got my floor pans stripped and cleaned up and Brodie got it painted Sunday. Cage is in, seats back in and inner lap harness anchor points mounted into the tunnel with plates etc. ISC strut tops on the bilsteins now, more travel better height adjustment. Still bit left but slowly crossing stuff off the to-do-list. Giving lexan rear screen and door screens serious thought. Not a huge amount to be gained but every bit counts. Also Mr Kuc confirmed ID2000's work with PFC's so that's a bonus E85 won't be too far down the track. AFM will be the only real restriction. Can't wait to get back into the snotter and get out to a SAU day
You could get away with ID1000s and bump up the fuel pressure. Thats what I did with mine. Was good for 475rwkw thru the auto. Brad makes well passed 500 with his
yeah to be honest mate thats prob all I'll run. I know a few blokes on the mainland making 390ish on nismo 740's at 3 bar, so 1000's will be more than enough. For me anyway!
I always think i need more power when i havent driven it in months but usually when i get back in it on the twistes or basky i shit my pants with 17psi/320rwkw's hahaha. touch wood the new suspenion setup and improvments allow me to run more and gain something =)
haha and new rear tyres matey. yep, there has been some looptey loops in her, it was manbearpig.
the last thing that i really want before I'm gonna be happy (for awhile anyway) is a good adjustable rear diff. Still, the improvements to the rest of the old girl should make it easier to cope with whats in it.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
