Nah just saw it on there. Was considering putting a bid on it but decided I probably have too many cars as it is. Looked like a pretty easy repair
Yep , i wasn't going to bid on it either , but i was on there watching something else :blush: , if the damage is worse than it looks in the pics i'll probably just wreck it
Buy the rota p45 from Rota aus on facebook, $1099 including delivery for 18's
cheers for the heads up, just checked them out wanted to go 18x9.5 +12 & 18x12 +20
but i dont want to hack my front guards or go wide rear, so thinking i may have to go 9.5 +32 & 10 + 35 :glare:
as im thinking +12 all round would still need guard work even though mine are allready rolled
interesting, mines quite abit lower then yours though.
i failed before the fronts would be +25 not +32
they have.
18x9.5 +12, +25
18x10 +12, +35
18x12 +0 +20
so thinking ill need 9.5 +25 fronts & 10 +35 rears
this 33 has 9.5+12 all round and looks mint! but no specs on camber ect
Edited by Autumn33
so after working it out on the offset calulator & then getting the trusty ruler out, im thinking i should be able to just get away with the +12's with some more rolling/lipping & stretch
Edited by Autumn33
Not too much to update. Last monday I put a new water pump, idler bearing/new Bolt and tensioner bearing on the old girl along with a new gates timing belt.
Yesterday arvo I made up my rear wing/boot bracing. very light and holds my weight very easily. I have made up a ally plate that fits nice in the passengers side of the boot to mount the surge tank and pumps/pump mounts to so it goes in and out as one piece. will plaster the rising sun over the tank and plate to mtach the engine =)
I'm at a bit of a cross roads with weight atm. I've sorta came a bit of the way and not quite sure where to draw the line. The head unit and 2 door speakers are in question, door intrusion bars along with door glass, might trade it for lexan... I would love to gut the doors and power windows and just have lexan in bare doors but I also want to keep from the B pillars forward in tact. I really want a carbon boot lid and then mount it on pins/latches and do away with the big factory hinges but that will have to wait as the money needs to go on more important stuff ATM
Got a ally rear diffuser/air guide planned for the rear. will get that underway in the next few weeks. more to aid airflow than provide any sort of extra dwonforce as ATM air can get trapped in the rear bar/boot floor area.
cheers
OMG, so much porn in those pics. Heaps jelly of your aero. If I had it though I'd just go backwards over a curb with it :P
Swapping Glass for Lexan I think is time to draw the line, skyline glass isn't that heavy anyway! You're better off spending the $$ on petrol and Tyres :)
its hard Nowelly. I need a new rear screen anyways. And I have spoken to Burgz about getting 2 orders shipped together. should be able to get a rear screen and door screens (and quaters but prob wont use them) in lexan here for 600ish. I was quoted over 300 for an aftermarket rear glass screen.... the door glass is actually kinda heavy. I know the rear isnt.
A nice light motorsport battery is def on the cards later in the year after the important stuff is out of the way.
haha yeah really its not huge coin. not when your already up for a rear screen anyway. its usually about 700 but if we can get two kits at the same time should save a bit on postage, shipping 2 kits compared to one shouldnt make shit all difference so should come in around the 600- maybe 650 tops. I prob wouldnt of bothered if I didnt need any but since I need the rear, kinda a 'may aswell while i'm there' thing lol
looking good Jack
cheers
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
