I got federal Evos on the front for Drift.
I think Federal RPMs are the ones you want though, you want a slight stretch too to help keep the tyre stable while drifting which helps with steering definition.
Dave.Tas is the dude you want to talk to tyres about, best prices. PM on here or add him on Facetube. http://www.facebook....hp?id=648679391
Edited by zoidbergmerc
Pretty sure federal rpm's are for your nans Astra, comfort street tire. The rs-r's are their flagship performance road tire. Not their semi, that's the Z something
Thanks for the replies. I reckon we'll just shim it up and see how it goes, its cheap so if we don't like it we can always look at other options and we're not really out of pocket. We're thinking of giving it about 3mm of preload as well.
The only reason I was thinking of running semi's on the front is because we already have some Dunlop 03G's, otherwise I probably wouldn't bother. I was wondering initially if they would have trouble getting up to temp but after thinking about it, from the couple of times I've been to Baskerville they seemed to work OK from cold. I guess the main thing I'm concerned about is how quickly they will wear, so how much do fronts wear when drifting?
i used to run Semis on the front when drifting. it all depends on the pressure you run. i ran yogies A048s and they were grate. i ran some dunlops once and they were horible. had no feed back through the wheel and understeered like crazy. if you start the pressures high they grip well. only time they are rubbish is when they go off after neumerous runs. happened at power cruise. hot day and multiple laps non stop.
when i was competing i never had issues with understeer but many of my compeditiors did.
as time has gone on ive since gone back to plane old 595ss as. with decent car setup for drift under steer isnt an issue but i wanted "slip" in the front to carry angle for longer. the tyres look like hell after a good day of draging.
in sumary. if you have them they will be better your average tyre. if they dont seem to be getting hot put more pressure in them.
I don't know from experience or anything close to it :P but wouldn't it be pretty damned hard to get them up to a good working temperature at the start of the runs, giving you less traction than normal?
Maybe someone like Djrift or zoid (or anyone with drift experience) could confirm?
yes i've tried it , no i wouldnt reccomend . was on a 32 4d , would have no front traction on entry then bite really hard mid corner!
This up and running yet mate?
Yeah man not on the road but got it fired up late sunday arvo. Spent two days diagnosing why it wouldn't fire turns out I needed to remove the injector resistor pack with ID1000's. Got to tidy up a few loose ends this weekend and hopefully book it in to get a run in tune in the next few weeks.
Hit me up for the cheapest prices on Federal RSR "semi slick" on 0409 631 092, or for any of the more street federals or kumhos. I wouldnt run a sticky dunlop soft racing semi slick on the front for drifting because you want some slip, but federal RSR is perfect, as shown by the huge number of people using them for it. I can also hook you up on federals and other varietys for the rear :)
Unless your pushing well over 300rwkw I wouldnt be looking to upgrade to GTR rear axles/diff/etc, Shim the diff really tight and dont look back, mine and all of the cars i have done are basically locked but still allow the diff to slip before the axle will break, and personally I wouldnt have it any other way
Diff came out Thursday night, shimmed it up Friday and went back in today. It had 2.2mm preload already, upped that to about 2.8mm. Haven't taken it for a test drive yet, will probably go for a quick squirt tonight.
Yeah ideally we would have liked to go a little more but we had a 1.4mm shim available to us, it had 1.4 and 0.8mm already in there so we just replaced the 0.8 with another 1.4mm. It had only just started to one wheel a bit so I reckon this should be enough.
got a few ods and ends sorted over the weekend
finally got around to replacing my Vac lines, had a few start to melt yonks ago at basky.
dropped my subframe down pulled the calipers off and shocks out and cut the top out of the rear of the subframe bushes and hard mounted it to the car, aluminim subframe lock rings in the front and on the bottoms. altered the antisquat (and a tiny roll centre change) by around 7mm or there abouts. wont go spacing the front down to take anymore out til i drive the thing
today i tracked down some condute at good ol superchoip, got the loom from front to back of the car covered and secured and looks nice and tidy now. also did the boot wiring to the tail lights and fuel pumps/relays etc, much neater.
got the rear diffuser/air guide measured out and planned, will pick up the ally this week to start that
started painting my surge tank and tank/pump base plate, that will soon wear the rising sun, to match the cam/valley covers
list is getting smaller! =)
Edited by Mr. Untouchable
Good work there Jack good to see it's getting a bit of attention again. Wont be long and I'll be bugging you to come to Basky every 5-6 weeks lol. I got a bit done on mine over the weekend trial fitted my half finished splitter and started making a catch can/radiator overflow (well cutting it out so Jack can make it lol) oh and I broke another thermostat housing and hacksawed my thumb..... :angry:
post-58307-0-49650400-1335086821_thumb.jpg post-58307-0-65970700-1335086877_thumb.jpg post-58307-0-85398900-1335087238_thumb.jpg
post-58307-0-91774200-1335087264_thumb.jpg post-58307-0-63403400-1335087305_thumb.jpg post-58307-0-04980100-1335087332_thumb.jpg
oh man, the hacksaw is gonna have to go on the "brodie do not touch" list like the stanley knife! blody hell.
and yes basky every 5-6 weeks is fine by me! spent the last 12 months preparing for that shit
ahhh you can just feel that datsun love =)
todays efforts.. Half completed rear diffuser/air guide. Still. Need to make the small section on the passenger side of the exhaust and the batman fins but the hardest part is done.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
