Well I've promised myself i wouldn't buy any more car parts until i sell some , im confused with what wheels i should put on it though , i have gold sparco rims off the 33 or the p1 i was going to put on blue 32 or , im tempted to put the sp1's on it , i have way too much shit for one person ...
finaly got my self a brand new t04 turbo, external waste gate, rising rate fuel pressure reg and 48 side draft weber(draw threw setup), in the prosess of getting the manifold cleaned and nickle plated, then water and methonal injection :)
just waiting on a few small bits and pieces to take her off the road again and get some boost happening :D
hoping for about 300HP ish.
enough to have some fun with....
800hp Turbo for 300hp? :/
Edited by jangles
Can anyone recommend a good place to get side skirts fitted and painted and front bumper resprayed? Obviously no one wants to pay more than they have to but i'd rather pay more for something perfect as the product remains after the money is forgotten.
After a perfect paint match and don’t want any orange peel, prefer both items painted off the car as it is currently a perfect respray and don’t want it ruined with overspray :yucky:.
Cheeeeeeeeeeers in advance
I'm looking to probably sell my R33 if anyone is in the market for one. Black, manual, rb25det, registered, no defects, coilovers, advan rims, all electrics etc. 11k ono.
Reason for sale is moving to another state soon and will probably just pick something up there.
Well , i finally got my track hack going after replacing the turbo , small issue , i took the old turbo off thinking there was a problem with it , i pulled it apart and found nothing wrong with it (apart from a small crack in the rear housing, and me breaking the rear wheel off while taking the rear housing off) , i put the new turbo on and it's still making the same sound! . Nfi where to look , all the gaskets are new etc :( so back to the drawing board... I think i may just have to register it and then change all the manifolds and piping (to after market etc)
Have you tired pressurizing your cooler piping etc?
Not yet , it sounds like the compressor is touching the housing , but it doesn't because i checked all of that out before i put it back together , it's quite audible from the air filter , which gives me a big ??? . Only gasket i haven't checked is the 3 bolt one that comes off the compressor , i can't see it being that though .
it's prolly that one, Toffy.
aaaah, the infamous Kennedy car. Never saw that video before - needs more engine/exhaust music ;)
I made that video last night :)
Edited by zoidbergmerc
I have no doubt in my mind it is that or the housing itself , with my luck , it would be the hardest thing to change , or the simplest . Either way , it's a good excuse to use the ceff setup :D . So Mr Kennedy has got his car to the track finally , about time , plenty of $$$ there , i was waiting for him to have a go! Tell him next time you see him that i said he is soft! .
So i sold my teks last week, since then car has been on jackstands untill tomorrow when i pick up my new wheels.
I will post up a pic either tomorrow night or wednesday but untill then im not saying what they are.
I have a feeling i will be doing a fair bit of guard work / going wide guards though :)
should be with the money invested in it! Pumped to be a passenger in it at some stage though.
Would rather be the driver! Especially if the owner wants to drive lol *waves to Blake*
more pics of yours with the wheels on it?
Edited by toffy
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers)
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
