Hey!
I have a coolant leak on the passenger side of the engine.... well thats where the drip is under the car anyway...
Me and a mate originally thought it was that stupid 3inch hose on the drivers side (thats a bitch to get back on too!!) But after starting up...theres still a leak...
Thinking it may be the hose feeding coolant to cool the turbo... (or hoping, coz i don't want it to be the water pump!)
Has anyone else had a similar problem?
Understand its a pretty stupid question, as everyones car is different....but if theres a hose thats prone to go on the RB20DETS it may help me out.... (have only owned car for 3 weeks....its my first turbo too...)
Cheers for ya help!
James
https://www.sau.com.au/forums/topic/91239-r32-gts-t-coolant-leak/
if its time to change timing belt its not a big deal if its water pump.You can presurised water system by testing pump and have a look when engine is not running.I have engine in garage I can have a look what is on passenger side anyway.Give me some idea where is leaking from.
Edited by familka gtr
If its the water pump, wouldn't it be leaking out fast..? Coz its just a drip...
Underneath the car it would be lined up near the turbo area...
Its strange, because i noticed the leak two weeks before it decided to over heat, and it was fine in that two weeks, then all of a sudden it went three quarter hot. When i looked under the car, it was dripping faster.... But now its just back to the minor dripping...
Hopefully that made sense.... :)
Yes they do. I just did a search for "coolant leak" and got this thread, my R33 s2 dropped about a litre of coolant today, and that's just after having the coolant system flushed and replacing the water pump! So it's not the water pump.
I'm buggered where if i know where it's coming from, the farthest i can trace back without starting to pull shit apart is the top of the left engine mount; I noticed a drop of coolant there. Basically what JC said, for all the world it looks like it's coming from the air side turbo / something very close or feeding to it. The other strange thing is it seems to only occur when the engine is cold... However this could be cause it evaporates from the heat before it has a chance to reach the ground/engine mount/whatever.
This just after I think everything is fixed! god dammut. Somebody help us! anyone with their motor pulled half apart around? If not it'll be me tomorrow... I'm meant to be going to the damn Indy and I have a 600k trip to do to get there!
Okay so I just had a quick look on fast... IF it IS coming from the turbo, which i reeeeeeealy hope it isn't, it would probably be leaking from either of the connections circled in red
As I said, I reeeally hope it's not that.. but then, I'm not quite so sure what i'd prefer it to be...If anyone else can shed some light!!!!
Hmmm yeah jezzerr....I was thinking its that too...
But mine happens after it has warmed up....i just started it then and let it idle....after a couple of minutes it started to drip... i had a look underneath, and i can see coolant around behind the water pump, but it drips on the passenger side of the block..not where the pump is...but i guess it could run there....
Could be just a gasket?
How much do you reckon it would cost to get the pump replaced...and the timing belt since you have to take that off...
the guy at import spares reckoned $500!!
I got an aftermarket pump off the shelf! Exactly the same as a VL commy pump - same block. 91 bucks. Going slow it would take one person 4-5 hours to replace. To illustrate, once me and my mate knew what we were doing, it took us an hour and a bit, go to whoa, using all hand tools. It's not really as hard as people make it out to be, you just have to accept that there is no quick way to do it, and it's pretty systematic from there. Just make sure you mark the timing belt location on the cams and the crank, and take good note of the slack in the belt, and remember to only make it as tight when you're putting it back together. Otherwise you have to pull the freaking thing right back apart again!
Timing belts are $140 ish, $60 odd for good coolant, so that's $300 odd in parts, and in all reality it should only take a qualified mechanic with all the right tools 2 hours to do the job, but you can bet your life you wont get the job done for $400 anywhere. add that to the fact that they'll probably find "a worn fanbelt" etc, and you'll be up for $600 at least, vs a day getting to know how your engine works.
Meanwhile, my leak has started up again, I pretty sure it was slow enough that it was just evaporating while the motor was still hot. feeling around as best I could, it doesn't seem to be coming from the turbo... sigh.
it'll run off the lines and not appear to come from the turbo if there is a leak up near the washer..
look, all you have up on the passenger side is either coolant feed or coolant return to the turbo.. so if it is definitely in that area, its definitely the turbo or the lines.
Yeah i got a mate that knows how to replace the pump, so can help me out...
I wanna change the timing belt anyway so thats all good....
Hmm...have to work out my finances by the sounds of it, and i just sold my old car too!! FARK!
Thanks for the help guys.
sounds like your turbo coolant pipes .. they have copper washers as gaskets, replace them
Yeah thats what i thought before... But now i can actually see coolant underneath and behind the water pump area...
  • 6 years later...
having a leaking problem too. only happens sometimes after a long drive. once i stop turn car off it leaks coolant for about 10mins. but no sign of it missing from the container or the radiator :S not sure if its coming from turbo line, when i floor the car past 4k revs makes a funny screaming sound now. no one can seem to help with it.
Edited by AndreW_R32
Jesus 7 year old thread dig up and youve created a new thread.
The screaming sound is probably the studs on your exhaust manifold check all the nuts are up tight I had the two on on number 6 cylinder loose making that noise.
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
