I have a 1993 R32 GTS-t with the rb20det and has the following mods. Full 3inch exhaust, pod, FMIC, 040 fuel pump, R33 GCG stage 2 hiflow turbo (rate at 450hp) apparntly people have run them on 20psi so thats the plan with it. I am about to get some r33 gtr injector, resistor, z32 AFM and then i am going to get the standard computer tuned at a Hyperdrive (place in perth that do a lot of standard ecu tuning).
My question is am i about to waste around 2k getting the injector AFM and tune, as my car will still be very slow? i am planning for 13's and 300hp at the wheels at least. I just don't want to spend all this money and get disapointed.
cheers for any input and help
Anton
https://www.sau.com.au/forums/topic/91317-300hpatw-in-a-auto-r32-or-not/
13's should be easy with all that hardware. however leave the auto as it is and it wont last long at all. If you plan to keep it auto then minimum a tranny cooler should be installed. Dont have to go aftermarket, a external r33 tranny cooler should do the trick.
let me know how you go, i too have a auto r32 and hoping i can get high 13's with just a warlbro 255 fuel pump, R34 factory side mount interooler, 3 inch dump and front pipe, 3 inch cat, boost up to 0.9 bar on stock turbo and tuning with a safc2. i already have the cat back exhaust and cat and air pod.
ok cool may give that a go then new supercheap store has just opened near me so ill see what they have. I was also thinking a shift kit like one of the MV or whatever it is called. But would this cause a problem with traction on gear changes. Apparntly shift kits are good for the box as they allow better oil flow
just wondering with the oil cooler with i just bypass the oil cooler that goes into the radiator (haven't looked just gguessing that is where it goes) and then just use trans cooler hose (rubber) to the new cooler.
Also lastly what sort of size would be best? i have a gtr front bar with a front mount so ill have to put it in the side vents of it
i have brought all the parts i need now, injectors, AFM, resitor i am just wondering am i gona have traction problems at hi revs and still the crap take of speed.
Off the line my car is a slug from standing start, its gona kill my quarter mile times, i thought of getting shift kit but i figure its not gona make a difference for take off and traction may be bad enough at gearchanges anyway.
ANyone else have a fairly quick auto and can give me some advice? i dont want ot waste 1k on tune and still have a slow car
PM Abo Bob, he has an Auto R34 GTT which is regularly raced at the track and drag racing meets, and has made the suitable upgraded to his Automatic gearbox to perfect quite well at both :D
yeah stall will be exspensive thought.
This is the detail for the r33 going to have a look today1995, done 138K but engine was rebuilt at 100k to fit the arias
pistons,RB25DET (unsure of mods previous owner insisted the pistons are Arias forged)
Apexi airflow
Cusco Struts
HKS SSQ BOV
BLITZ Boost controller
Radiator just serviced and channell cleaned
HKS Heavy duty 3 puk clutch
New hoses and water pump
Interior:
Nismo dash unit
HKS boost guage
Quik Shifter
Internal blitz boost controller unit
pivot turbo timer
Exterior:
White
GTR skirts
GTR rear spoiler
GT400R front bar
3 inch blitz exhaust with chrome cannon back
5 spoke 17" near new tyres
Sunroof
I don't like the front bar but supose i can sort that out. Overall i prefere the look of my car but yeah the fact its is manual and a 2.5litre may just make it better. Unless i go see it and the interior and outside is poor conidtion ill just keep mine and go head with tune
Sounds good.
Those 400R bars have never been my thing.. They look a little out there for my liking.
I personally think there's nothing better to look at than a non-kitted R33 slightly lowered sitting on a set of deep dish rims.
They look fat.. :angry:
Start throwing on the body kits I think it tends to ruin them..
yeah i don't like it at all but i could change that easy enough problay sell it and get standard or gtr bar but i don't like chances of gettting a gtr bar for it.
Does sound ok though but could be a dodge rebuild and yeah gona have to get another turbo again and injector and all that will see. Cheers for the resistor cubes, i sent a pm but i don't think it worked came up with error. where would you recomend to fit it? its bigger and more shiny than expected.
Depends how much wire you have available.
I think the best position is where it fits up on the R30's.
Behind the left strut tower right next to the loom.
You could find somewhere else but its best to keep it away from water.
Edited by Cubes
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
