if its shaky den it's wheel balance..
I had the exact same problem, took it in for a wheel balance (obvious solution)
When they jacked it up at the shop i had a look and the dick before me had put spacers in (to push the rims out), which was the cause of my tyre hitting the wheel guard at every little bump, but when i took the spacer off i noticed there was no hub locater. The lack of a hub locater meant that the rim had play between it and the hub. Machined up two of these little bad boys and problem fixed =no shake
This will only be a prob (i think) if you have aftermarket rims and if the guy that had the car before you was a dick, or the dodgey dealer you bought your car from was also a dick (had these problems)
Cheers
Or it could be as simple as a wheel balance -- easier fix too
https://www.sau.com.au/forums/topic/91458-shaky-at-100km/#findComment-1667531
Wheel alignment will fix how the car travels down the road. If you take your hands off the wheel and the car continues to track straight then the wheels are aligned.
If there are vibrations, then it is probably (with exceptions like mentioned above) going to be wheels out of balance. Most balancing centres can only balance 16-17" rims. I tried to have some 18"s balance and had to have them driven across town to find a big enough balancer. Without casting dispersions upon the guys that did the balance, they may have taken a short cut with your balance if they didn't have the right equipment.
https://www.sau.com.au/forums/topic/91458-shaky-at-100km/#findComment-1671760
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
