Chaser spotted
I saw my first chaser (Mk4 I think but dont quote me) today whilst launching the boat to go fishing :rolleyes:
This was at the boat ramp at the end of Katanning street just off Guilford rd. If you know your geography this is on the same street as A&B auto's who are a compliance mob. It was black with chrome deep dish 5-7 or so spoke mags and was a manual with blowoff valve.
I could tell it was a manual and had a blowoff valve cause the driver was umm erm testing the handling characteristics of the car:rolleyes:
I'm not sure if it had dealer plates or not so does anyone know if they can be complied as yet or is the sevs procedure still being gone through?
Anyways it was bloody schmick, sounded awesome and although very camry/cressida looking it made me look 5 or 6 times.
P.S. Ken your GTR hasn't moved from the front carpark since Tuesday except to bring it in at night. Dont be suprised if they take longer than quoted...again :D
https://www.sau.com.au/forums/topic/9155-chaser-spotted/
I thought that C Red has a black chaser ?
Not up on ny Toyotas but know its some 2jztzettdohc type thingo.
Car will take longer cos theres no front seatbelts in Perth. Will be ready mid next week.
Cheers
Ken
https://www.sau.com.au/forums/topic/9155-chaser-spotted/#findComment-137313
Hi Rhino,
As of now there was only one importer who could get the Chaser 2.5twin-turbo (JZX90) in, and that is Cannington Auto Wholesale, Frank is the owner and I think the cars go for $25K. I do believe that C-red are bringing them in soon, as they make awesome drift cars. The Chaser, Mark II and Tourer V are all the same car with minor differences.
There are also a number of LX90's , which is a 2.4L diesel turbo , my mate owns one, they look good, use F/A fuel but have no real performance.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9155-chaser-spotted/#findComment-137390
GTS-4OrCeD,
Unfortunately most of the ones around are LX90's, the turbo diesel. You can tell as they have the down-turned exhaust. The 1JZ engine is fantastic, what I used to have in my Supra, so although they don't look quick they can hand your ass to you if you don't expect it.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9155-chaser-spotted/#findComment-138201
i have a jzx90 mark2 its is modified 5 speed.
i was a bit worried when i bought it but it has supassed every expectation and more let me tell you this thing should be abale to pull a 12sec quarter for those who want more info post here i will reply
https://www.sau.com.au/forums/topic/9155-chaser-spotted/#findComment-138249
Guys,
My Mark II is a JZX100. I also had a Mark II JZX90 which I got rid of. Both the 90 and the 100 are available in Chaser, Cresta and Mark II, with different front and rear ends basically. As a guide my JZX100 has 260 odd rwhp and is as quick as the GTAAH rolling start. Its fcken nuts. We'll have compliance available for the JZX100 within 2 or 3 months.
Jash
https://www.sau.com.au/forums/topic/9155-chaser-spotted/#findComment-141561
Hey vspec i was driving an import b4 u were an itch in ure daddies crotch!! j/k :sperm: so for all us ppl who dont buy mags. 1.4 ton? or same a supra? ya know how toyota love the "solid build" lot more than i can say for nissan tinnies and their "lets save weight and put in a weak engine"
*stir stir*
https://www.sau.com.au/forums/topic/9155-chaser-spotted/#findComment-141587
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
