can anyone help me. I have bought a manual boost controller and once i put it on things were going fine, i set it around 10psi to 11psi on stock turbo and stock intercoller. However after a few weeks it started to loose power under boost at the high end of the boost range, about 5000 to 6500, sometimes even earlier. It almost sounds like it is backfiring. I have thought about air/fuel mixtures and the timing or that it may just need a simple tune. However i feel that there is a biger problem behind this, so if there is anyone out there with suggestions that would help, i would be greatfull
https://www.sau.com.au/forums/topic/91683-skyline-running-badly-help/
My boost controller got disconnected when I installed my car alarm and it was just boosting and boosting, when it hit boost and was almost at the end of the gear (hitting max boost) it would back fire and almost sound like it was hitting the rev limiter. I realised that the boost controller wasn't working, got it to work again and never had the problem. I think I was hitting the boost limiter from the ECU.
Check to make sure your boost controller is working.
Greg
do it yourself
theres a tutorial in the FAQ section on how to remove your plugs
once theyre out, grab a feeler gauge and the plugs only require a little force to decrease their gap to the set level on the feeler guage
then pop them back in
easy as!
Get the plugs out of the motor and when you look at it there is a little bent piece that sits over another rod in the plug, the gap between these two pieces is your plug gap, where the spark is created, now get a feeler gauge that is 0.8mm thick and if it doesnt fit between the two widen the gap till it does, it MUST be a close fit so you feel it contact with both sides. Look at the plugs and consider thier condition if the rod bit is flat on top with sharp edge around its in good condition.
I was talking to a mate of mine and he said that it may be because it is not getting enough fuel, is it possible that a fuel pump could fix this or is it deffinatly the plugs.  Just eant to make shore in case i stuff something up.
heheh everyone always thinks they aren't getting enough fuel. Ever wondered why your car blows black smoke under load?
Its because the stock ECU runs rich as f**k.
Dude, as soon as you increase the boost, there is more air in the cylinder, causing there to be more resistance between the plug gaps, causing them to miss fire.
Before you touch your fuel pump, or anything else, GAP YOUR PLUGS.
Its the easiest, and first thing you should do. This is a VERY well known thing with the RB25det, and any other forced induction car.
You need to GAP YOUR PLUGS.
Do it first, THEN look at other things.
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
