NISMO edition R32 GTR, 36,000km's ***PRICE BUMPED TO $30,000***
Build number 219 of 500 Nismo R32 GTR, fully optioned from Nismo.
36,000 kilometers, the car is in original and immaculate condition. Located in NSW.
NISMO edition factory fitted options (not aftermarket):::::::::::::::
Nismo Uprated Turbos (T25/T04B Turbos with metal turbine blades instead of the stock T25/T3 ceramic bladed stockers) this engine was known as the "PLASMA RB26DETT"
Nismo lightened - 60kg lighter then stock GTR
Nismo Exhaust + dump pimp (full exhaust)
Nismo Fuel Pressure Regulator
Nismo Grounding Kit
Nismo 320km/h speedo (original speedo)
Nismo side skirts
Nismo ("N1") Front pods
Nismo Bonnet Splitter
Nismo Rear Wing
Nismo Adjustable Dampers
Nismo Short Shifter
4 core aluminum radiator
Cross drilled rear disc brakes
New Exedy Twin Plate Clutch with slave cylinder (worth over $3,000) and still has a 25,000 km Warranty.
New Rubber all round (traveled 3,000k's)
During compliance I spent an extra $3000+ and replaced any items that may of been potentially warn due to age. This included fitting a new Garnett Racing Timing Belt, Harmonic Balancer and Front-end bearings, drive shaft boots and a fresh clutch. (as well as oils, filters, fluids naturally).
My car seems to have several more Nismo options then the regular Nismo editions and there may even be several other Nismo modifications to the car as the Nismo's were special orders. Here is some information from another SAU forum member::
"From the study and findings i have from contacts here and in Japan it seems that the Nismo spec are almost unique between cars like when ferrari releases a special Ed car-its almost like they were ordered in Japan from new to the cutomers specs and desires, which is why there are differences betwen the indiv cars-so ther are no concrete spec lists on them as they vary as I mentioned"
Apart from these Nismo factory options the car is stock, no boost controller - the turbos have never run anymore then factory boost and the car has never seen any track work, it's just a weekend driver.
Exterior Pictures:
http://www.powerlock.com.au/r32Nismo/DSC00230.jpg
http://www.powerlock.com.au/r32Nismo/DSC00231.jpg
http://www.powerlock.com.au/r32Nismo/DSC00233.jpg
http://www.powerlock.com.au/r32Nismo/DSC00234.jpg
http://www.powerlock.com.au/r32Nismo/DSC00240.jpg
http://www.powerlock.com.au/r32Nismo/DSC00241.jpg
http://www.powerlock.com.au/r32Nismo/DSC00244.jpg
http://powerlock.com.au/r32Nismo/DSC00246.jpg
Interior, engine bay NISMO serial number on the firewall (NISMO Serials read BNR32-100XXX, standard GTRs read BNR32-000XXX):
http://powerlock.com.au/r32Nismo/DSC00256.jpg
http://powerlock.com.au/r32Nismo/DSC00251.jpg
http://powerlock.com.au/r32Nismo/DSC00252.jpg
http://powerlock.com.au/r32Nismo/DSC00253.jpg
http://powerlock.com.au/r32Nismo/DSC00250.jpg
http://powerlock.com.au/r32Nismo/DSC00254.jpg
http://powerlock.com.au/r32Nismo/DSC00258.jpg
More pictures available upon request.
Immaculate, fully-optioned 1 of 500 NISMO edition GTRs with 36,000 genuine km's.
$30,000. (No swaps or trades sorry). Regretful Sale..
Contact me on 0413 980 100 or [email protected]
Edited by ScottKing GTS-4
  • 3 weeks later...
Thanks mate... To tell you the truth I'd rather be selling a few body parts but no body wants any of mine!
please excuse me while i drool...
Nice car. Just wonder if you are sure that your speedo is factory 320kph? becuase my understanding is that they were all released with 180kph speedos to comply with japanese rules.
Edited by JASSPEED
Me too, that 320kph speedo even though it has Nismo on it would be an aftermarket (or after factory ) piece. They left the factory with the 180kph speedo and with the 180kph speed limiter in tact and its a common mod to reomve this and put in the 320kph speedo. This could have been done almost as the car left the factory so kms on the clock could well be accurate-the thing is it is hadrto ever know,but check any service stickers on the air box and they may give you a clue. I didnt think the stock 418cc injectors would allow 300+kw-I thought they ran out of duty cycle at around the 270kw mark-The car does look outstanding!!!!
Thanks mate - you're doing well with 2!
I was told my car had been optioned with the Speedo, 4 core radiator, cross drilled brakes and even the twin-plate clutch. Do either of yours have any of those features?
The base options on the Nismo Editions seems to be a bit of a black area - I've been unable to find any "official" records of what the base Nismo's actually ran. I've also posted several threads in this forum and others to try and find some facts and figures.
I've also spoken to another fellow who owns a Nismo and his doesn't have hieght adjustable dampners and from the pictures I saw of his car it appeared it even had the stock GTR exhaust system on it.
Nice car. I have 2 geniune Nismos of the 500 released. Both have 180kph speedos. Just wonder if you are sure that your speedo is factory 320kph? becuase my understanding is that they were all released with 180kph speedos to comply with japanese rules.
No it's all factory fitted. And yes it is making well over 270kw. If you're interested in actually buying the car then I'll take you for a drive and show you.
No more time wasters please. If youre interested in the car let me know. Technical discussions about the flow rate of stock vs Nismo injectors belong in the technical forum.
Interested but the color is a concern as no Nismo's were painted blue to my knowledge. Please confirm the paint code on the Nissan ID tag for me. If it was repainted another color can you tell me why?
BTW I also agree with other comments that the Nismo only had a 180klm speedo and it was probably swapped over.
Thanks
It was re-sprayed in Japan and before you ask - no, there is no accident damage evident anywhere on the car.
The guy who did the compliance, Nathan over at Grey Imports (recommended as being one of the most reputable Compliance shops by these very forums), commented that it was one of the cleanest re-sprays he's ever seen come out of Japan.
Give Nathan at Grey Imports (Sydney) a call - I'm sure he'd remember the car and vouch for it's over all quality and I'm sure he wouldn't mind the call considering how much extra work I got him to do on the car while it was there (front end bearings, tensioner, timing belt, etc). Grey Imports 02 9519 5150
Thanks
Thanks
all GTR's had the chassis no. written inside the front and rear bumpers in chalk...its an easy way to tell if its a crashed car. TWO.06L had both numbers clearly written on front and rear.
hi scott, nice looking car. could i ask do you have the auction sheet available to confirm the no accident history, also any paperwork to back up the very low kms (especially considering the aftermarket speedo fitted). Just that i'm sure you realise that a reading of 36K is not worth the premium unless it can be substantiated.
Thanks.
Thanks for the tip, when you say inside the bumpers did you have to pull them off or are they in a spot you can see them?
If the car has any accident damage it was either fully rebuilt by Nissan themselves or little elves sprinkeled magic fairy dust on the car and undid any accident damage.
Anyone interested in buying this car, go have a good look at a few other GTR's THEN come and see this one. That's the best advice I could give any of you.
Cheers everyone.
All you have to do is see that car and you'll know the km's are genuine. You will not find an R32 for sale in better condition.
Cheers.
Thanks.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
