if i use these struts in the hr30 do i have the use the r31 insert or will the r30 insert fit?
i'm getting a set for my r31 gxe, but wanted to put them in my hr30 for compliance cause i have to take out the coilovers, i can still use the r32 calipars and rotors on the import r31 struts...
Edited by rsx84
https://www.sau.com.au/forums/topic/91960-hr31-struts-in-a-hr30/
From memory, the R31 struts are shorter than the R30 inserts. You will need to use the R31 strut and insert complete (and if you are doing it for compliance / rego purposes only, why would you care).
Oh, and when you find a second set, just shoot me a PM please... :D
Cheers,
Matt
The Australian built R31 struts are different to Japanese built ones. The inserts are different between both.
Most import sedans and coupes have the same struts and inserts, though I have heard that some of the R31 imports (RB20E/RB20ET models) have a strut more like the Australian models that have a non floating hub, which severly limits your brake upgrade options.
So I guess go with a set from anything RB20DE/RB20DET powered and you'll be right
i've got the konis book here and they class the sedan and coupe as the same insert??
Yeah,they are different though! Spacers under Aussie inserts is rather dodgey too,as the top of the Jap inserts are different shape to Aussie ones as well! And the import struts have a solid top hat with a proper ball bearing race,as opposed to sloppy rubber ones for the local model.
ok the question is. you say they are 1" shorter in shock length, would this also mean the total lenth of the strut is shorter?, can the R31 fronts be bolted in onto a hr30 ?
If im thinking right, that would lower it 1"
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
