Well thats quite strange as your only using a relay?!? :S
I remember the relay is in the boot inside the drivers side guard as if you follow the wiring thats where it goes. I think. :dry:
Ok thanks Cubes, ill have a play with it and try and sort it out. God i hate these stupid problems. :sleep:
The relay was under the rear boot trim on the drivers side, it is a green relay and plug.
Ive tried to wire this thing up every way possible with no success, it does work fine until you switch the car off then reds stay on but car stalls so there must be an issue with the turbo timer somewhere that is causing another problem.
Put the wires back to standard and the turbo timer works fine.
Ill have another play with it this arvo as i would like to get this fixed up before the tune on monday but if i cant get it sorted i guess ill leave the malpassi reg in it with the pump at 10.9 volts.
Turbo timers are over rated anyway. :huh:
Ha ha yeah but then my dash will look stupid with
A: A turbo timer that doesnt work, or
B: A spot where the turbo timer was glued on. lol.
I unplugged the factory relay and plugged wires in to connect it to a different relay and everything works sweet at 10.9 volts, then i tried joining the 2 blue wires together and use this for the trigger and connected a fused 12 gauge wire from the battery on the relay. Starts fine with 13.6 volts but at shutdown the timer will not keep the car running.
Does it really matter if it isnt getting positive from the same old place? Who would of thought one relay could cause so much trouble.
I think ive wired it up every way possible as well.
Not sure this is right, going by memory but the 30 and 85 are your coil and 86 and 87 your normally open contact and therfore the 12 volts fused should be on 86 and the fuel pump trigger should be on 30. I think that is correct but only going on memory
I just wired up a relay this afternoon and all was going fine untill i turned the car off, now the turbo timer will not keep the car running but the ignition stays on but the car just stops. If i put the wires back to standard its fine, i tried using another relay but get the same result.
Everything was wired up right
30. 12v battery fused
85. earth
86. fuel pump trigger
87. fuel pump
Any ideas on what could be going wrong?
Does anyone know where the factory pump relay is.
Thanks.
85 and 86 are the coil :(
Gave up on it anyway, have the pump running full voltage now so ill work something out with the timer later.
  • 1 month later...
How many L/hour pump capacity do you need for 300rwkw?
Is a Nismo fuel pump by itself enough (its 4.1L/min I think), I'm going to use Nismo 740cc injectors.
Can someone tell me whether I still need to get a nismo fuel regulator?
Edited by Edge
ok i just read every post in this thread and im more confused than ever.....does someone have photos or a diagram showing what has been done.....i get that you run power cable from the +ve batt to the relay to the pump, and ground the pump to the chassis.....then how do i wire up the oem pump wiring to the relay? oem +ve to +ve on relay? then oem -ve to relay then -ve on relay to chassis or oem -ve straight to chassis.....hope this makes sense :)
Cheers
  • 1 month later...
I am in the process of upgradeing my injectors to GTR injectors and I think I will be doing the fuel pump wireing upgrade if I get time aswell this weekend, if not it will be next weekend.
I was actually thinking of just rewiring the whole system still retaining the voltage drop circuit (located in the boot.) for lower flow @ idle (basically just replaceing the thin wire from the fuse panel/relay/dropping circuit back.) I don't know how difficult it will be but I should be right.
Now the only thing is does anyone know where the original pump relay is located?
If it works out I'll take a few photos etc.
Oh yeah and I am using a boch 040 intanke pump.
Edited by RedDrifter
Sounds like a good idea Reddrifter..
There's a couple of relays in the boot. Follow the wires and you'll find them. They are located in the rear guard so a little bit of a pain in the arse to get to.
As in the right hand guard near the voltage req circuit box for the pump?
Not completely sure. :S
I do know there's a couple of relays in the drivers rear guard that have wires entering/exiting from the fuel pump loom section. I'm unsure if the high/low switching occurs there or else where.
The R33's from what I've seen don't suffer the same large volt drop as the R32's; their battery is in the boot so no doubt this does help some what..
14.8v if thats correct is overcharging a tad. Keep an eye on it.
OK I had a bit of a play this avo and I measured 12.25 volts at the positive wire of the pump, so My car isn't doing to bad.
In the rear drivers side guard is the fuel pump modulator and in the back near the boot release is the pumps relay.
Would I be loosing much from the Bosch 040 @ 12.25volts at idle rather than 13.8?
oh yeah, you definitely will. Like lighting, the smallest drop in voltage sees big gains.
e.g. with lighting, having the headlights at 11volts, the brightness is almost half that if the voltage was 13.8volts.
However, bear in mind that yes, it will flow more if you do the wiring, but do you need it? e.g. if you have a big pump, you might not need to potential extra.
For my cars, i've never bothered to rewire it. The stock pump wouldn't be enough for me if I rewired it, and the aftermarket pump flows enough, so I don't find the need to wire it.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
