Yeah, he's talking about the white Blitz R34 4 door, that & the HKS silvia are the D1 cars. They are easy to drift straight away, better after some personal tuning.
But in this game you can't "really" drift, once you hit opposite lock the car snaps back the other way & you lose it. It is a racing game, but everyone loves to drift. :D
Apart from that, take any decent rwd car onto Tsukuba wet, it's a good starting point & a good challenge to hold it, as it dosen't snap back on you. I have some good drift pictures I've taken, but nothing to transer them to my pc. :P
https://www.sau.com.au/forums/topic/92132-gt4-drift/#findComment-1667159
lol i can link some corners
don't turn too much on 1st corner keep the line in the centre if u go too wide you slide on the grass which can be good or bad or if you go too close to the apex you ll spin out.
lowering the gear and holding handbrake helps...I could even drift the 89 GTR lol shame i cant upload pictures but.
for suspension set-ups go to www.gamefaqs.com
https://www.sau.com.au/forums/topic/92132-gt4-drift/#findComment-1667432
drifting is possible you just have to have your set up right. cars that i have found the best are sileighty, 4 door blitz r34, and supra. having traction control and stability control on setting 1, sticky tyres, and using nos to loose rear traction are things that make the car better to drift. using the handbrake is difficult as it is hard to keep the revs up.
https://www.sau.com.au/forums/topic/92132-gt4-drift/#findComment-1675546
  • 3 months later...
GT3 is far beta for drifting, try the r32 gtst an the rx7 series 4 or 5 i think, they are the best cars to drift in, u can drift in GT4 i do all the time it just takes alot of practise an again use the rx7 or 32 even the s2000 i can get to drift. i'll put sum pics up if u can tell me how to gem em off my ps2.
https://www.sau.com.au/forums/topic/92132-gt4-drift/#findComment-1976732
ossie_21, it's not easy to drift in GT4 but it is possible.....
check out some of the GT4 videos posted here. Some of these guys are insane.
I can manage to link a few corners but not really more than 3 or 4 before I come unstuck. It doesn’t really matter what car you choose as long as it's a rear wheeler and the power and suspension is adjusted appropriately.
My preferred choice of weapon is usually the series 6 Bathurst RX7, Gallant VR-4 or my BMW M5. The Beemer is a big lard so it's easy to loose it around a corner as there is just a little to much weight to throw around.
HR32_GTS-T, you need a USB flash card to get the pics, simply plug it into the PS2 copy the photos (in the "home" section of GT4 mode, and then plug into PC and copy them over.... they are saved in JPEG format.
here is a shot of my Beemer...
https://www.sau.com.au/forums/topic/92132-gt4-drift/#findComment-1976843
here's a "little" video i came across (81megs), but it shows exactly how drifting can be done. This is by far the most impressive video i've seen. This was not done by me unfortunatly.... but it's really worth the download and if your like me... it will inspire you to try drifting in game again....
http://www.fbidrift.com/video/bloody-drifting-2.wmv
https://www.sau.com.au/forums/topic/92132-gt4-drift/#findComment-1980879
in gt3 you cant get full lock steering unless you are rolling at like walking pace so how do peopl drift effectively? in gt4 its probably the same otherwise you would have to have a feather touch on the joystick. unless youve got the driving force pro steering wheel :P
https://www.sau.com.au/forums/topic/92132-gt4-drift/#findComment-1981243
I found an odd and different car for hanging the tail. Its one of the alpine-renaults in the french section. Its the later model of the 2.
If you can get that thing to go straight you are doing really well.
It just doesnt have the power to back it up.
Give it a go anyway, its kinda funn.y
https://www.sau.com.au/forums/topic/92132-gt4-drift/#findComment-2001470
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
