Yeah, he's talking about the white Blitz R34 4 door, that & the HKS silvia are the D1 cars. They are easy to drift straight away, better after some personal tuning.
But in this game you can't "really" drift, once you hit opposite lock the car snaps back the other way & you lose it. It is a racing game, but everyone loves to drift. :D
Apart from that, take any decent rwd car onto Tsukuba wet, it's a good starting point & a good challenge to hold it, as it dosen't snap back on you. I have some good drift pictures I've taken, but nothing to transer them to my pc. :P
https://www.sau.com.au/forums/topic/92132-gt4-drift/#findComment-1667159
lol i can link some corners
don't turn too much on 1st corner keep the line in the centre if u go too wide you slide on the grass which can be good or bad or if you go too close to the apex you ll spin out.
lowering the gear and holding handbrake helps...I could even drift the 89 GTR lol shame i cant upload pictures but.
for suspension set-ups go to www.gamefaqs.com
https://www.sau.com.au/forums/topic/92132-gt4-drift/#findComment-1667432
drifting is possible you just have to have your set up right. cars that i have found the best are sileighty, 4 door blitz r34, and supra. having traction control and stability control on setting 1, sticky tyres, and using nos to loose rear traction are things that make the car better to drift. using the handbrake is difficult as it is hard to keep the revs up.
https://www.sau.com.au/forums/topic/92132-gt4-drift/#findComment-1675546
  • 3 months later...
GT3 is far beta for drifting, try the r32 gtst an the rx7 series 4 or 5 i think, they are the best cars to drift in, u can drift in GT4 i do all the time it just takes alot of practise an again use the rx7 or 32 even the s2000 i can get to drift. i'll put sum pics up if u can tell me how to gem em off my ps2.
https://www.sau.com.au/forums/topic/92132-gt4-drift/#findComment-1976732
ossie_21, it's not easy to drift in GT4 but it is possible.....
check out some of the GT4 videos posted here. Some of these guys are insane.
I can manage to link a few corners but not really more than 3 or 4 before I come unstuck. It doesn’t really matter what car you choose as long as it's a rear wheeler and the power and suspension is adjusted appropriately.
My preferred choice of weapon is usually the series 6 Bathurst RX7, Gallant VR-4 or my BMW M5. The Beemer is a big lard so it's easy to loose it around a corner as there is just a little to much weight to throw around.
HR32_GTS-T, you need a USB flash card to get the pics, simply plug it into the PS2 copy the photos (in the "home" section of GT4 mode, and then plug into PC and copy them over.... they are saved in JPEG format.
here is a shot of my Beemer...
https://www.sau.com.au/forums/topic/92132-gt4-drift/#findComment-1976843
here's a "little" video i came across (81megs), but it shows exactly how drifting can be done. This is by far the most impressive video i've seen. This was not done by me unfortunatly.... but it's really worth the download and if your like me... it will inspire you to try drifting in game again....
http://www.fbidrift.com/video/bloody-drifting-2.wmv
https://www.sau.com.au/forums/topic/92132-gt4-drift/#findComment-1980879
in gt3 you cant get full lock steering unless you are rolling at like walking pace so how do peopl drift effectively? in gt4 its probably the same otherwise you would have to have a feather touch on the joystick. unless youve got the driving force pro steering wheel :P
https://www.sau.com.au/forums/topic/92132-gt4-drift/#findComment-1981243
I found an odd and different car for hanging the tail. Its one of the alpine-renaults in the french section. Its the later model of the 2.
If you can get that thing to go straight you are doing really well.
It just doesnt have the power to back it up.
Give it a go anyway, its kinda funn.y
https://www.sau.com.au/forums/topic/92132-gt4-drift/#findComment-2001470
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
