whats the point in having it if your not going to use it if ur ugnna drive around with it u might as well say you have it?
Are you talking about insurance?
Coz it would be a damn shame to be forking out $3000 a year for insurance for a few years just to finally make a claim and have it rejected because you wanted a carbon bonnet.
https://www.sau.com.au/forums/topic/92167-cf-bonnets/#findComment-1661935
Its also illegal to have one as its not designed for the car. So technically not even insured
I dont think you can even engineer one due to material used
This is the reason ;)
We all know Police read the forums. Say Joe Bloggs admits he has one in a far fetched or maybe not so world, it gives them something instantly to go after Joe for to defect. People dont want to admit to anything they dont need to. I wouldnt, would you? <_<
Joe with his CF bonnet has an accident that has nothing to do with his bonnet. Most insurance companies seem to be of the opinion, guilty until proven innocent. They dont want to pay out unless they have to. If as a company could get out of a $5K claim on a technicality, would you?
Anyone can and does read the forums. People are aware of that. :D
The only GTR I know of that can have one legally is the N1 which I am sure someone can either confirm or deny as it came from the factory.
https://www.sau.com.au/forums/topic/92167-cf-bonnets/#findComment-1663388
I had a carbon bonnet on my R33. Cant tell you about insurance cause i didnt tell them..lol
But i lived around the eastern suburbs next to knox, and YES i got alot of attention. Defect after defect, although none of them were for the bonnet itself..lol. IT draws alot of attention, 2 days after i sold it the guy got defected for the bonnet
https://www.sau.com.au/forums/topic/92167-cf-bonnets/#findComment-1667015
ffs. As if saying on here that you have CF bonnet will get you a visit from the cops. As someone said, you drive around with the bloody thing on so what's the diff?
How many of us post that we have bigger injectors, turbo etc and get visits from the cops or the epa?
What a wank.
https://www.sau.com.au/forums/topic/92167-cf-bonnets/#findComment-1668120
What a wank.
A very constructive reply there from an Exec. ;)
All I know is I wouldnt be putting a post up about doing any illegal activity on somewhere I know is frequented by Police. Makes sense doesnt it? :)
Do you have any other suggestions as to why people dont post up that they have a CF bonnet. :D
https://www.sau.com.au/forums/topic/92167-cf-bonnets/#findComment-1668185
What a wank.
We dont post in the Vic section... anyhow.
go to Nissan Silva, ask what happened to the Vic boys about thier cars and the defects from what came about on the forums.
it might be very surprising to you, but common for us here
https://www.sau.com.au/forums/topic/92167-cf-bonnets/#findComment-1668774
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
