  • 3 weeks later...
  • Replies 66
  • 3 weeks later...
A front bar support is a thing that bolts to the chassis and holds up the bar (usually no actually connection from the support to the bar).
Mine is made of fiberglass composite and I got it from "JS" for $220.
My experience with JS was less bad but I'm sure I can find someone in my local area (ie. Silverwater).
T.
Guest 382 GZV - 4 Door R33
Does anyone know a place in Queensland whio are good to get bar work done at? I've been to two you were apparently 'good' but they suc for service and quality and now I'm thinking i may have to wait to summernats when i go down south to get any work done...
Now I'm worried. I've got a UAS GTR fibreglass front bar which clearly had to be fitted by having a large centre section of the metal bar that runs behind it chopped out of it. No doubt that dramatically reduces the strength of the framework.
Unfortunately I did have a prang the other week and it certainly seems clear looking at the damage that the metal bar did nothing to relieve the impact in any way. It's just totally buckled. Now I'm in a panic to see if the insurer is going to kick up a stink and tell me that the car cannot be insured for the accident because of this mod. I'm so not calm at the moment!
If anyone has something to say to make me feel better....
Originally posted by slayer_1971
I thought that the front bar support also helps in front colisions
I don't think this fiberglass support is gonna do shit unless the accident is like at walking pace...
The car was COMPLETELY unsafe prior to the support - at least something is holding the bar up and them is some crumpling of the support if there is a big hit.
This really is a dilemma - I don't know if the steel support should be refitted or is this good as it gets?
T.
I really don't know if you know what you are talking about Regan. I have a friend who has been fitting body kits for years....especially Skylines, and the idea of putting an after market frontbar on is so that it looks different to other Skylines. He says that of course you have to cut the support bar to fit them because THEY ARE DIFERENT! If you don't want to cut the support bar then don't fit an after market frontbar! I also see in one of your posts (see following post) that you sell a frontbar THAT YOU HAVE TO CUT THE SUPPORT BAR!! So obviously you think its OK to cut them, BECAUSE YOU SELL THEM.
regan
Newbie
Car: soarer
R33/Nismo bar
Hi
The front bars are $580.00 incl GST freight to Melb would not be cheap @$80-120 I think ,
Note*** these bars do require some front crash bar modifications to fit and would need some additional supports to be fitted.
Cheers
Regan
My friend also says that he doesn't fit small support struts underneath as it makes it even more rigid which does greater damage if you run into a kerb. Without the support struts there is more give allowing it to flex a little when you hit something. Fibreglass frontbars are so light that they don't need many bolts/screws to hold them on anyway.
Jim
has anyone got a pic of what this support is exactly?
Im a prospective r33 buyer, and im curious as to what your reffering to.
I know that the soarers have a large aluminium reinforced rectangular section bolting on to the front chassis rails which supports the front bar. Im visualising something similar for the r33, but im not sure exactly.
Thanks.
hey Regan, my brother bought his skyline from you a few years back :-) hows it going
I had exactly the problem you talk about with my car (i'm in melbourne), i only found out about it when someone ran into the front of my car in a low speed impact and tore most of the front kit up, it was poorly fitted at the front and screwed into just the headlight structure, with the front bar cut out :-P Luckily it was the other driver at fault so i got it repaired properly for free with the bar restored and reinforced with side struts too
hey jim the support bar may be the only thing diffusing the impact to the sides enough so that the engine doesnt crash through the firewall into your crotch in a big impact so hey, if you don't miss it thats your problem
  • 1 month later...
My front bumper support has been removed I think...I got the kit and car from Just Jap..and I am guessing they removed it...
So are you saying that a front mount counts as support and if i get it inspected it will be alright/legal again???
Or can I get a front bumper support put on??
  • 3 weeks later...
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
