mum1fy is that horse they had to put down after caufild cup its an aust and world champ blah blha somee one into horses would of paid abit for it..they rang and said i cant have it idiots....
then i wanted BT1WPN for some young guy to buy...but by 4pm it was taken so was BT1JET....they love there vl trbo's hahahah
end of the day im getting a refund...
  • Replies 241
Posted Images
Vic roads must have some on the ball people as I would over look some. There must also be some plates that mean nothing to some cultures but are offensive to others.
I rekin half the 1's that get rejected is just the operator at vic roads saying "oh nah, you cant have that plate sorry", then they just order it for themselves. how hard is that to do? not very.
LoL....doubt it man.
There's no conspiracy theory :P
its not a conspiracy
if you worked there and are taking all these calls for plates that will sell for 000's, why wouldnt you want a piece of the action, especially when you have hundreds of calls coming in everyday telling you what plate to get
LoL...true.
But their incomes aren't that great, how many are they gonna buy?
Plus A LOT of these plates won't sell for squat.....how many people do u think ACTUALLY sell their plates for 000's? In the words of Scribe, not many, if any.
Most rich people are dumb
Edited by darK
Hey allblitz - what have you got to do wiht a Falcon Ute that is always around the city with 19" rohs?
It's always parked out the back of my work and has a www.allblitz.com.au sticker on the back window
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
