  • Replies 43
hmm. ive said this before but i dont know much in about the wonderful world of cars. but my research has shown me that r32's have less muscle, (but the gts-t r32's are legal for the victorian p plater)
thats all i know.
at least i tried :)
https://www.sau.com.au/forums/topic/92764-r33-vs-r32/#findComment-1674466
Listen to the man^^  :D
^^Yep listen to this man :)
I just bought an R32 but only because I love the 32 shape, the 33 really does nothing for me unless its a GTR :)
But tbh if I had no preference I would probably buy a 33 because the prices of 32 and 33s are very similar these days and the RB25 would be better bang for your buck :D
https://www.sau.com.au/forums/topic/92764-r33-vs-r32/#findComment-1674725
Yeah I'd go with an R33, RB25 power. Nicer interior than the R32s.
Plus, I don't like the look of R32 GTSTs, but that's purely subjective.
R33 has better torque, feels quicker. The R32 felt like it handled better, but I think it only felt that way.
By the way, I've owned both cars so not really biased either.
R33 GTST.
If you're talking GTRs, then I'd go the R32, purely based on looks, bang for buck. But the R33 GTR is a more refined car in every aspect and look great, but only in purple. :rolleyes:
https://www.sau.com.au/forums/topic/92764-r33-vs-r32/#findComment-1674868
R33 GTST.
If you're talking GTRs, then I'd go the R32, purely based on looks, bang for buck. But the R33 GTR is a more refined car in every aspect and look great, but only in purple. :(
totally agree...
https://www.sau.com.au/forums/topic/92764-r33-vs-r32/#findComment-1677816
I have always said R32 and that 33's are whales and so forth.
but with todays pricing, and REALLY comparing what each cars gives you (not including looks) the R33 wins hands down.
the only thing the R32 has over the R33 is the weight advantage (I think 70kg lighter) and looks which is subjective.
R33 has the better engine, better gearbox and I think slightly larger brake disks and calipers..
engine and gearbox alone is worth getting the R33 to the R32 for me.
and I guess that will mean I will be a whale owner in 2006.
if the R32 was so much cheaper that you could have an R33 engine and gearbox put in and drive away at a total cost (including car purchase) of $15K then I'd do that.
but the 89 gtst's are just crap.
and 93 gtst's are same price if not more than Series 1 R33's.
anyway, you really need to make the choice on which you like the look of better.
both are good cars.
https://www.sau.com.au/forums/topic/92764-r33-vs-r32/#findComment-1677925
If you are asking from a purely "better buy" perspective then a series 2 R33 is the better buy as the ass has fallen out of R33 prices and you get a newer car with fresher engine and a little better luxuries.
From a taste perspective then only you can decide which you like more.
https://www.sau.com.au/forums/topic/92764-r33-vs-r32/#findComment-1677931
take an r32 for a drive.. you can say what you like, but take an r33 for a drive, and then the r32, and the fun factor is so much higher in R32.. I love driving it all the time.
I'd never go back to an r33 after owning my 32.. 34 possibly but thats about it.
If you like a modern car, get an R33..
If you like to work on your own car, buy an R32... then you can work in an rb25,etc for pretty cheaply yourself.
https://www.sau.com.au/forums/topic/92764-r33-vs-r32/#findComment-1677980
My r32 with something like 155rwkw felts ok till I got in an RB25 powered car.
then mine just felt gutless.
no torque feels so crap.
but then again, some people like how the RB20 gets up and going on higher revs.
I'd rather torque and no high revs.
That's why it kills me to read all these people with 30dets already up and running.
https://www.sau.com.au/forums/topic/92764-r33-vs-r32/#findComment-1677989
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
