13.4 second 1/4 for your 'stockish' R33. (A how to guide).
Originally posted by R33NT
The article did a before and after dyno run showing there was an actual gain (i dont remember how much) in removing the mesh. Anyway you dont technically force more air in there you actually suck more air in there and the more tubulence (caused by something like a grate) the less flow you get!!!!
Anyway as long as you are careful not to leave the filter off and the filter is internally clean when you bolt it in then it wont cause any problems.
dont do it, i did it and the actualy gain u get is not even noticeable!
I get surges and weird idleing sumtimes after i pulled mine off!
yep, I should have mentioned I have removed the mesh.
It would improve airflow a little (it's quite obvious because it is a restriction), not so much power you'd notice though.
The mesh is there to stop knuckleheads poking screwdrivers into the hot wire. It certainly not there to smooth airflow beacuse the mesh is cheap ass and not completely even due to cheap manufacture.
Re the surging that you are seeing, i think that it has something to do with the air flow meter measuring differently with a lower restriction input. I know that in my Apexi PowerFC you actually have to tell it if you are using the standard air box or a pod filter so it must affect the measured value in some way and with what i assume is a standard ECU in your car it could be a problem.
Again this is only an opinion, talk to your mechanic and see what he says.
Rev210, I'm glad to see you get a better response than you did on the SDU forum. That was rather sad - conjured up memories of when I posted my dyno results; same dyno as everyone else uses, but nobody wanted to believe it. It seems if you get something better than others they don't want to knnow about it. As I said in the "other" thread: Go the whale!! :D
Guest MFX_R33
I went out to Eastern Creek a few weeks ago and watched 2 very similar GTSt's with FMIC's, running about 12 psi each, that could not get better than a 14.7. They had varied launches from bogging to wheel spin, and they couldn't get any quicker (not sure of the mph).
I decided to take my car down there last week to see how it would go. I left it in full street trim, with 18"s, full tyre pressure, system and spare still in the boot, and HKS coil overs. I did a 13.737 @ 105.41 mph.
I am thinking of going back soon, with my stockie 16's with 15psi in them and seeing what I can do.
Vishes, you said you prefer to run in street trim. If that is the case, then why would you strip out the back of the car?
Jeff.
BUSTED! :Owned: :)
Nice numbers Jeff. EC isn't the easiest track to get good ET's on either! Speaking from experience.
EDIT: Just noticed Vishes had already stated he runs minus seats etc... Removing interior is no longer "street trim" IMO.
Street trim to me means - out of the garage, down to the strip & off you go! That's how I run my car, nothing different to how I drive it 100% of the time. I've never even dropped my tyre pressures :)
apparently you can put 235 tyres on the stockies. i know you can put 225 tyres, coz we have a few cars here that have 225 tyres on the stock rims.
any disadvantage of puting 235 on the stockies? i would say its a great idea!
cheers
Guest MFX_R33
My coil overs are HARD. Rev as far as I know you want softer suspension for the 1/4 so the car can squat off of the line. This helps the weight transfer, and give the rear more traction. From memory the ideal is to set up your rear shocks with a really soft compression, and a hard rebound. This way the car can transfer the weight onto the back wheels, and will slowly come back up further down the track.
Jeff.
MFX_R33,
The front is the make or break part. 90/10 shocks are best but, boy are they crap for driving around town.
If you have the diff cradle angle right (ala' cradle pinapples) the rear will squat regardless. The stiff front end is where the trouble starts.
I have standard 'soft' rear suspension and it does me no favours. Stiffer rear setup would get me a better 60ft
Going back to the tyre size question,
Which set up would net a better 60ft time?
1) 17" mags with 255x40x17 (36psi)
or
2) Stock rims with 225x50x16 (15psi)
Very interested to know which ones would obtain a better result.
Stock suspension.
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
