Hey guys, in the near future i will be upgrading my fuel pump. now my first option was like a bosch 040, but then i will get the qtr tank syndrome wont i ? cant use the last qtr of the tank properly?
Just after a pump that can handle 300rwkw (wont be going for that much power) just to be safe tho.
and works just about 100% the same as the stock pump. Would it be an idea to get an inline pump instaled ? Would this work ?
what options do i have to play with
https://www.sau.com.au/forums/topic/92922-fuel-pumps/
  • Replies 40
gtr fuel pump should be fine for your requirements.
direct fit and easy to hook up. why do u want a pump to suit 300rwkw?
do you know how much its going to cost you to get to 300rwkw?
the pump is the last thing to worry about
https://www.sau.com.au/forums/topic/92922-fuel-pumps/#findComment-1677113
That quarter of a tank business is a load of rubbish - it just depends on how good the installation is. You've got to get the pump as low as possible in the tank. So many people install aftermarket fuel pumps in tank and don't do the job properly. I even saw someone on these forums mount his in tank onto the factory fuel pump mount with DUCT TAPE!!
Working in the fuel tank of an r33 is a real bitch - the fumes kill half your brain cells and you'll have no skin left on your fingers.
I did an 044 in tank into my r33 - If I were you I'd put my pump in line - it's just too easy. I have no problems getting over 500 k's to a tank and can run it down to empty.
Don't know about this talk of bosch pumps not working well with skylines - I've had no problems but mine runs flat out all the time without the factory speed control.
https://www.sau.com.au/forums/topic/92922-fuel-pumps/#findComment-1677411
i wont be getting 300 rwkw, i just want a pump that can outperform my cars fuel needs, its no good running a pump at 90% cycle, when u can get another pump todo the same work at say, 60% cycle, which one will last longer?
I was thinking about getting an inline pump, what one tho ?
hmm who in vic has had an 040 installed without the vibrations and the qtr tank syndrome ?
I want it to act like the stock pump, take it to empty if i wanted to sorta thing.
https://www.sau.com.au/forums/topic/92922-fuel-pumps/#findComment-1678064
I had a 044 pump fitted in my S15,the friend that fitted it went to so much trouble to get it in the EXACT same spot as the original.When my light comes on at 50 litres used,I always get exactly 50 litres in the tank.
I am in the process of replacing the pump in my GTR.The car makes makes 340rwkw on Racepace dyno,Ben assures me the stock 10yo pump is up to the job,as does Nigel at Ice.As Ben rebuilt the motor and tuned the car,I guess he'd know.The car also pulled 379rwkw in shootout mode on Racepace dyno.
I dont pretend to know as much as these 2,but I'm replacing with a Tomei in tank,rated as 276l/h.
So going by my GTR,the GTR pump should be fine in your GTS,hope this helps.
https://www.sau.com.au/forums/topic/92922-fuel-pumps/#findComment-1678087
having a pump that can outperform your cars needs is fine but there are inherent stuff you need to know above,as the guys have posted can't go below 1/4 of a tank. also when sitting in traffic (peak hour) and if you have a nice big pump every time you tap the throttle the pump runs on full mode and will pump like crazy so it will pump (i think it was 3 litres of fuel in a minute) for the 044.
so the fuel gets hot in rail and then pumped back again and repeats. also the stock injectors and fuel rail will max out well before 250rwkw so having a larger pump with stock everything else is really only half the problem solved.
my advice would be gtr 2nd hand pump, 550cc or 480cc injectors and nismo fuel pressure regulator. whats your power goal? all of those are useless if you only want 190rwkw
https://www.sau.com.au/forums/topic/92922-fuel-pumps/#findComment-1678125
I originally had a 040 in my R33 and couldn't use the last quarter of the tank. I then lowered the pump in the tank (was told this was bad), took it to a workshop and was told that 040's aren't good in Skylines. So now I have a Walbro one instead. I can't say that the Walbro pump is better than the 040, but now I can use the full tank and it doesn't make anymore/less noise than the 040 did.
Could you get the 040 to use the full tank if you could attach a sock on the end like the stock one? I know that the 040 doesn't have any place to attach one, and that the filter is built in to the pump, but could the sock solve this? My brother has a 044 modified to work in tank and this was achieved by fitting a sock to the end. So if you can modify the 044 with a sock, how about the 040?
"They taste like burning!"
https://www.sau.com.au/forums/topic/92922-fuel-pumps/#findComment-1678150
the walbro's are rated at 15volts. the wiring in the r33 only supplies 13.5 volts or thereabouts so it will never flow its potential unless you upgrade the wiring (cubes has a thread recently on how to do it)
https://www.sau.com.au/forums/topic/92922-fuel-pumps/#findComment-1678158
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
