Important fact to remember, in a drag racing senario the actual power transmitted to the pavement is alot different to the dyno graph. Unless you are willing to rev/antilag and dump the clutch on the dyno, then while the turbo is still spinning and has built up inertia change gear. Will show a completly different curve as turbo motors are not static output as a N/A motor would be. The graph would be alot fatter with more midrange/earlier boost "response".
Having said that, who the fcuk races a car from ~2,000rpm up to redline in 4th? Or has a direct drive dragster/rail that has no gearbox? That's the only result you can estimate based on these chassis dyno graphs...
  • Replies 146
There are a number of guys over here who can vouch for simon's TO4z setup as being a very attractive alternative to 2530's. The 'response' as people are starting to point out is to do with a stopwatch and how fast the engine spins up and boost/power happens, from this perspective the TO4z does infact seem to do this as well or perhaps even a tad better than the traditional 2530's with the added bonuses of more power, less moving parts, less parts in general and more room in the engine bay.Lets face it we are all looking for that pot of gold where we get fewer trade offs.
A good friend of mine has been lucky enough to witness the road going comparison to 2530's and although there where some engine differences it's very obvious the turbo delivers the excellent response we expect from 2530's from purely a timed delivery perspective (from on the gas to go).
At the end of the day I think the proof is in the pudding as they say, so Simon you just have to take a few more of us 2530 twin owners for a ride so we can back you up :D
what mods have you done becaues i am chasing 400 all wheel kw, currently doing 241awkw i have
power fc+controller
avcr, currently trying to tune it
high flow turbo. running 1bar
3.5inch catback exhoust+ 3inc high flow cat currently getting 3inch dump/front pipe the exhoust and cat has been added after the dyno
after market avr intercoller, looking at a better intercoller
Generally speaking, people want different things from their cars. So keep their GTR's stock, some pursue lap times, others drag strip times.
At the end of the day, anyone who owns a GTR that wants to run 10s on pump fuel without nitrous, is going to have to have to sacrifise response for top end power. You really cant have the best of both worlds. To some a 2500RPM power band is all thats needed, to the track driver it needs to be double that. 415 kw at the wheels is huge, and is enough power to post a 10sec pass, thats a great achievment. To some it wont mean much, they may look at a GTR with N1's that can do 1.40s round eastern creek as impressive. Critisising the response of a particular setup/turbo combination is fairly petty IMO.
jesus pnblight cant u say once that u think single turbos are ok, u are constantly on ya bloody twin turbo bandwagon, gives ya the shits, and simons has done an awesome job and proved it where it counts, and congrats simon u deserve plenty of respect mate :)
just an observation peter in the years ive been on the forums u never give credit to the single setups ever!
cheers
Brad
hehe, its not that bad m&m
Sometimes everyone just gets a tiny bit too passionate.
Its very rare.
Guys - just knock it back a notch. We all have our own beliefs.
Dont try push it upon one-another unless your using given fact as opposed to what you think works best, which at the end of the day is all that matters :)
Top effort Simon, will have to look out for you car next time I am down at the 'plex.
Just got myself back into another R32 GTR and I am very tempted to build it up but might wait until I finish the zed before I get carreid away.
Wonder how the TO4Z compares to the GT35R...
Geez Cuong - the only build that I know of that's taken longer than my R is your Z!! :lol:
I have a bit of a comparison between my car and Morgs' car on the same dyno, with 0.1 bar of boost difference. Very much a different response. I will post it up with Morgs' permission ... but not for a couple of days
Congrats on the result. The T04z people seem to be pulling big numbers
Thanks for the reply brad but i think u might go past me horspower power wise as u got a nice forged crank to rev ut hard and 2.7L ! I would like to try miine on 2 bar in a few weeks with some bigger squirters and see what the t04z is capable of because at 24psi its showing no signs of letting up yet.
I think this is true to a point but with turbo techonology of today and eveyrthing else advancing so far i think you can have the best of both worlds now . I ran a 10.9 babying the stock gearbox , the car makes 454rwkw's and has a power band 4000-9000rpm .
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
