hi pplz i need a lil bit help
im chasing 350rwkw i had 300 but was to laggy
im getting the heads posted and polised today and new valve springs
also looking into some low comp pistons, maybe a gt35/40 also some stonger rod bolts i have the ignition setup already and fuel set up
i need some ideas the more the better also i also have a high mount manifold waste gate and im after some ideas for ecu
thanks
https://www.sau.com.au/forums/topic/93107-wanting-over-350-rwkw/
hang on, you just said 300rwkw was too laggy but you want more power? dont expect less lag? have you considered a 3 litre bottom end? adding another 50rwkw is only going to add "more lag" if you don't make the engine more efficient at the same boost level and / or turbocharger size
a healthy shot of nitrous will help you get there for a split second or two :P
this is just a idea n i dun no much bout the rb25s but im about 2 (rb25det neo coming for my r31 wagon this weekend :-D )... its prolly too late to say this now and might be innefective but wat about a neo head would your computer handle variable valve timing???... that got em a extra 30 kw or so along with bigger coil packs n some other stuff (pretty sure)
not bad thanks pplz i dint think ill be going to the 3lt bottom end would love to but cash might be a issue how hard is it to do
and wat does it cost
i had a t70 was a bit laggy but i still producced just over 300 rwkw on 19psi i think i want a high mount and also a ball bearing turbo for quicker spool
i need to know has anyone reground there cams as i heard this is a option instead of buying some
5000 rpm
im getting a high mount
need to know wat turbo to use i wat it earlier than that
i had a t70 standard manifold with custom dump pipe setup bosch 044 spitfires now im getting port and polish also wat are the best pistons im goin 20thou over
well my GT30 used to get on the money (17psi) around 4000-4200rpm, thats on the street, no "preloading" on a dyno or whatever.
That was 300rwkw at a max with that.
You want a bigger GT35, 350rwkw... its gonna be a little better than what you have now... maybe 500rpm at a stab.
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
