Hey all.
Just thought I'd post a few pics of a little project I made last week. Its a turbine (Jet) engine and it actually works. I have used a T46 Garret turbo (Off a 500hp cummins truck engine). At the moment I have it running on bbq gas but hope in the near future to convert it to run on either diesel or kero. The best I have had it running so far is about 14psi boost and at that it is making a HOLE LOT of noise. Hope to try and squeeze at least 20 to maybe even 25 psi out of it and then strap it to a go cart. :).
Edited by GTROB
https://www.sau.com.au/forums/topic/93116-home-made-jet-turbine/
Hey all.
That is brilliant mate! I must come over and check it out!
You know that used to use centrifugal turbos/turbines for jet engines back in the old days, then they went to axial flow turbines like they use now.
Check this out:
http://www.nybro.com.au/downloads.php
I work for GE, maybe I could grab one of our 200MW turbines and strap it to something. :D
Hey all.
Got the web page up and running. It's not completely finished so sorry if not every thing works. There is a small video on there so you can see and hear what it sounds like.
Web site is http://fulbosjet.com/.
Cheers and enjoy.
Edited by GTROB
  • 4 weeks later...
For those who are interested I may be in Adelaide next week end with the jet engine. (Got some mates that want to see it in actions). So if any one wants to come and check it out feel free. Will keep you posted on where and when.
Sweeeet :)
I've seen this done on many websites and wanted to try it myself :D Its a damn shame i have no engineering skills whatsoever!
Anyway, i read somewhere that this setup could spin itself to destruction... How are you limiting the turbo spin? Is there an automatic cut off if the turbo spins to a certain range?
I'm interested.. :)
Not likely to go bang. Well at least I hope not. The outer casting of compressor and turbine housing are big enough to contain ever thing if it does go bang. As it is a truck turbo they don't use a roller bearing set up. It's just a shaft running through a brass bush, so that would sieze before it blew up. I just control it by the tap on the gas bottle. As soon as you turn the bottle off the flame stops and the trubo spool's down. I'm not going to run it any higher than about 25psi boost any way, That will keep it in the working range of the turbo.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
