  • 10 months later...
Yeah, I was gonna say something about that :)
Cheers for the pics though, should make the guide a bit easier to follow, my photos are shockin. I'll put all the photos back in order too...
Just my 2 c insteed of cutting the pipe head down to enzed and get a barbed fitting for it so its all nice and neat and wont blow off
  • 7 months later...
  • 5 months later...
ok after reading all 10 pages i just want to make sure of something...
i will be fitting a hicas lock bar to my r32 gtr, do i join the 2 lines back there to each other so the fluid can still 'flow' ?
will this work fine? wont put strain on the power steering pump ?
just wana do this the quickest and best way possible,
thanks !
When I orginally removed my HICAS, I just looped the lines back into each other at the back of the car.
When I removed the lines and solenoid, I just looped it back into the itself under the resevoir.
I will now be utilising those looped lines to install a cooler :)
  • 1 year later...
Great Thread!
Just 1 Question - On the GTR R32,
When you get to the stage where you remove the Red Circled pipe in the Pic below and blank it off on the Power Steering pump,
BUT
Where does the Loose pipe go to, that you have taken off ??
Thanks!!!
It goes to the HICAS solenoid. I have just finished pulling all that out of my R32. There is absolutely no looping involved when you pull it all out. The front outlet of the power steer pump still just goes to and from the rack, and the rear outlet of the power steer pump doesn't exist, because you replace the old R32 pump with a newer one and get a new line made up. All the rear steer plumbing goes in the bin.
So you removed the section with the fluid cooler on the drivrs side as well . . . ? (where most loop the 2 pipes together)
All gone. My "cooler" has been out of circuit for years anyway because it had a crimp in it, was causing high pressure and leakage in the power steering circuit. So my car had been looped out there for a decade already. But now it's all gone. I plumbed a spare little auto trans cooler into the new power steering circuit to provide more cooling than it will ever need (trying to compensate for the previous years of neglect!)
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
