Thats easy, Nissan Nivara speedo drive, for $22 brand new from nissan.  And the red speedo gear that comes off the R33 speedo drive.  Put them together walla, working speedo.
Hey guys...
Sorry, new here - just learning at the moment! :huh:
Just a wee question on the above:
Did a manual conversion in my car a while back, and the box came with an electronic speedo drive - does this mean i have an r33 box? and this Navara speedo drive - red speedo gear? how does this work?
SOrry for boring newbie questions!
Hey guys...
Sorry, new here - just learning at the moment!  :(
Apparently one of my mates had a r32 box with an electronic speedo drive on it. So no idea. More commonly people will use a GTR speedo drive with the red gear, but at $50 second hand, the navara one is new, and cheaper.
good idea guys loving the info
quick qestion
inside the doors to do with the elec windows u have a black box.
is that the "window regulator"?
coz im was stuff and stuck on and made my battery go flat
i need a new one.....any idea what cars have the same
the window regulator is the mechanism that moves and holds the glass. i doubt it is that. it would be more like a window motor relay or somethin
David
hey... does anyone know what boot latch to use??.. mine is kinda stuck and wont close... really need help cuz my car is outside and had a mini storm today...
please help :D
Hey inside the boot is a latch under the locking mechanisim, you and "flick" or WD40/gease up that and you should find any sticking might be resolved.
Sorry if it's too late.
Cheers.
i need a new coilpack harness, RB20 ones are the same in Ceffy and R32?
i've heard that apparently the pins are different, eg one has vertical facing pins while the other has horizonal facing pins eg ( = and || ). if they are indeed different and ur current plugs are in decent condition you could always cut and swap the plugs.
i actually have a r32 engine loom that i'm putting in soonish on my ceffy motor. when i pull the middle channel cover off i'll confirm if there is a difference.
Edited by skypy12
Ok quick one. For the aircon, the little motor and cog box. Is it the same to any other nissan. Im talking about the one down near your left shin. It moves the air around, you hit the button on the climate control, and the air moves.
  • 1 month later...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
