hey guys, im new to this and need a bit of help
i just got myself a C33 Laurel ...
and i got a few things i need.
What exhaust would be simular to the same ?
R32 4 door?
S13?
obviously A31 will be the same
r33 seem to be the same length
what fuel pump cradle is the same?
R32?
S13?
R31?
a31 i think , the tanks in a31 and c33 are model specific as far as i'm aware
over flow bottle and windscreen washer bottle
A31?
R32?
S13?
seat belts
A31?
i heard rumors of R32 GTR?
c33 only , google search klippan , they can make them
I hope someone can help me with these as i have an I.D. inspection coming up soon.
Adam.
just buy a cefiro one, they're only $65 brand new from Nissan
or r32 , they're all the same 100% , vl fits but is crap
the r32 2 door exhaust is 4-6 inches shorter than the 4 door version ...
considering that the laurel and cefiro are the r32 4 door floor pan vertually i thought i would measure it up .... and it came very very close (measured it up off the car as my laurel is in-mobile at the moment)
it was a 3.5 inch after market item had all the same bends and length as my 3' straight pipe
that's funny because i've fitted a 2d r32 exh to a 4d r32 before and it fitted perfect! and there was no way it was long enough for A31/C33 , as i said above , i'm 99% sure r33 exh fits with only the center bracket being different (stock r33 doesn't fit but only because of the bend just past the diff fouling on a couple things ... you could make it fit)
Edited by toffy
C33 rollcage fits just got one
r32 gtst rear discs fit just drill to 4stud
to the guy after rear discs japaneseimportspares.com has 2 pairs in stock
C33 cage will fit A31 but its loose and doesn't contact the roof and pillars properly. Sits about an inch off the roof. Defeats the purpose of the cage.
A31 cage will fit C33 but it will push the roof up causin a rather large dent in the center of your roof.
C33 cabin dimensions are different to A31. The roof is lower and the doors come up higher as to give some structural integrity to the cabin as they are pillar-less.
Ah ha so 25det box in ceffie then. From memory i thingk you need navara speedo driven gear. swap it on the A31/R32 cable and thats it! Ithink thats all you have to to but dont quote me on it. I think you need to search the DIY threads, i konw there is a topic on here that covers how to do it in great detail.
Or do you mean it had 25de in it??
sorry, need to clarify... i've done the rb25 gearbox and navara gear drive conversion years ago... works great.
I was using the original cefiro speedo cable with it and all was good until the cable broke.
I got another cefiro cable from another cefiro and it did not fit on the gear drive end. which is why I just wanted to clarify part numbers etc.
cheers
i put a rb25 box in a 32 with the navara speedo drive etc , it fitted perfect , and i actaully used the speedo cable out of my cefiro because the r32 one was better condish (put the better one in my car lol) , but the r32 one fitted in the speedo drive fine when i tested it :( .
Edited by toffy
  • 4 weeks later...
seat belts
A31?
fairly sure r32 ones do fit as i bolted the rear set in, but u cant mix and match the female and male connectors with ceffy ones
just got some sr20de brakes for rwc and i compared them with my rb20e/de brakes
ceffy front brakes
rotors:
22mm thick
250 wide
pads:
111mm length
pad mounting groves on the calipers are completely different
calipers:
i didnt bother taking the pads out to check the piston size but the rear housing of the piston is much larger then the s13 one
silvia front brakes
rotors:
18mm thick
250 wide
pads:
98mm length
Tie rods ends are the same as a A32 maxima.
Seat belts are the same as R32, and Pre 1997 A32 maxima (after that they came with pretensioners).
Power window mechanisms are the same as R32 4 door.
Does anyone know what rear discs can be used on an A31? As the skylines have drum/disc combination brakes, which I don't think the ceffy's got.
and just to back up my statement ^^
also if this thread was cleaned up of the chit chat such as this current one it would be much easier to search as the answers to questions are spread across 12 pages
Edited by Dan_J
+ 1 to that, need someone with moderator privileges to make the changes since the disabling of editing posts... btw I've sold my ceffy (although do miss it :) ) so don't really look in this section any more.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
