  • Replies 41
Okay... here is the issue,, weight saving....I specialise in them.
The guards that i will be making is designed if u're weight concern, cut and replace that simple.
Rear wise i will be making them from the full boot line to the bottom parts. so at least 2kg each side u will save at minimum.
Front wise, it's simple replacement FRp item that will reduce lots and lots of weight even with the alumnum one.
Legality issue.... What about 400Rwkw ???? is this legal....
Edited by topstage
ummm, not exatly on a GTR but...
that's my widebody BN kit, it fits into the ridges between the door line and fits snugly in the back. But yeah the kit weighs a buttload. Its mostly for looks.
will you be fitting them or just developing them of the car, cause i'd prefer not to fit them just yet, don't have enuf cash for a respray just yet. if you can be sure there isn't going to be any damage to the car, i'd be up for it. i'll pm you some pics of my baby.
Also are the front's going to made as bolt on items? And how much wider than gtr guards will they be?
funkymonkey u haven't seen my kit yet, it's feather weight as i specialise in weight reduction. ppl, this is a chance to go for looks and DIET BRO....
Lukaz i can do anything as long as there is enugh time.
Black R32 i will be fitting theese and perpare them for sprays, u don't have to respray your whole car for this unit, it will be a bolt on no fuss and stuffin around.
Sarumatix Hmmmmmmm interesting...... not yet for the rears 4 door unit. have to develop the coupe then i will do the 4 door.
FOR interested parties, call me on 0401216460
topstage, do you run a panelbeater/prep/paint shop or is this in your spare time as a hobby? I'm looking for someone to prep my car for paint.
If you want you can use the car for a couple of weeks to develop your guards while you're at it.
I have a R32 gtr that I smashed up about 6 months ago a sandown doing a track day. It was going into the panel shop next week but if you are interested in it I might be keen. I will be doing all the track days next year plus more. The car will need a full respray due the the damage which I'll pay for, so after the job it would look like new. It has a HKS2.7 liter forged big bore kit with N1's and almost all the suspension sorted( might be bolting on high mount twin TD05's since I've seen a graph with these making 380rwkw at around 1.4 bar and I have the manifolds, less laggy than 2540's). The car would be an excellent example of your work. I'm not afraid to give the car a hard time, track, drift, etc and would be more than willing to promote your product it its good quality and you help me out. I'll pm you my ph no so give me a call if your interested. I have a straight R32 gtr at home as well so it you need a car to dummy stuff up on you could use that.
manage13, thank's bro, are u up for it?
topstage, I have spoken to various people about having the wide body done on my car however I was convinced otherwise. There are a few valid concerns they raised that are in my best interest not to take up your generous offer.
I know this may come as a negative post and by no means do I intend it to be. ABuSD stated in an earlier post that you do a great job and I do not doubt that! I believe this is a great offer for R32 GTR owners I wish I was in a different situation to take this offer up.
I don't want to take anything out of context. But was the statement "turned up gettin some hoons" on NS.com in reference to us? I'm not jumping to conclusions here! Maybe I have taken it out of context.
Regardless, I wish you all the best on your venture.
did you mean this manage13:
http://www.nissansilvia.com/forums/index.p...howtopic=123834
This top stage guy doesn't quite get it. I just spoke to him and all he had to offer was the quarters and a tin of paint for you to promote his product. I'd rather save the couple hundred dollars he had to offer to keep my car original car. And it costs you for the paint job. Who would do it?
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
    • I took it out, even though I knew I probably don't know what I'm doing other than looking for power signal lol. Lesson learned here I guess, even if it looks normal, worth checking as it only takes a few seconds anyhow. And maybe disconnect the battery, even though really shouldn't have to.
