Well hopefully this should stop him from making havoc here, but pump king/cefiro pwa is back under the the name driftspec13 on nissansilvia.com.
Here is a screen shot of parts he is selling.
Check out forum scams link for the low down on this guy or in the dodgey seller section on here.
forum scams link
If you see anyone selling the same stuff on here be careful!!!
https://www.sau.com.au/forums/topic/93707-buyer-beware-pump-king-is-back/
This is off the bad trader section on here.......
Known Nickname(s): Mines_Datsun, LaL, REDFC, Doridori32, Milk, blitz-gtr, Cefiro_PWA, crazy-sil80, pump^KING^007, turbo33
Names Used: Alex Kantarovski (Real name), "Petar", Alex Kantar, John Travison, Martin
Email: [email protected]
Email: [email protected] (he's also known for using various other email addresses ending in "supernerd.com.au")
Host: pacific.net.au
Host: tpgi.com.au
Phone: 0403 715 527
Phone: 0400 829 787
Phone: 9449 7731
Address: 60 Mcubbin drive Taylors Lakes, Victoria
Other Details: Bank: CBA Account Name: making-garage (BSB: - 063172 ACC: - 10188449)
Other Details: Bank: CBA Account Name: MIKI T (BSB: - 063172 ACC: - 10188449)
because if you deal with a large amount of people in buying and selling, each person is gonna have some little bit of info about you. Someone who didn't get jipped and picked up from his house may have given that address to someone who got ripped off.
Either way this guy owes a few people money. Not to be trusted.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
