  • Replies 277
Posted Images
Don't be silly, every skyline is welcome.
There could also be the chance for a photo of your car to be featured in a 2 page spread in a certain magazine!
Hope to see everyone there!
its ok i was only joshing anyways , but people only tend to look at my sleeper when i open the bonnet . And it goes grmm grmm , thats a growly sort of revving noise :)
Edited by dondesoto
Only a couple days !!
Hopefully the rain doesn't kill the numbers.
I am sure alot of people would like to see a 3 figure turnout this year...
and a 6 figure donation total !!... well maybe if theres special cookies available for $5 each (for passengers only)
Just incase anyone starts wondering, this cruise will still go ahead if it's raining..
There is kinda undercover parking at Aspley and there's also an under cover area at somerset dam.
As per above, the cruise will still go ahead if it's raining.
Have a good day everyone and drive safe.
I won't be able to make it this time, but any of the other club events have been great.
I hope you all appreciate Erin's efforts in all these events you get to attend...
Peter
