well starting to look into options to build up the old 20's bottom end as power and age is starting to take its toll on the old girl.
i think that i am gonna go with arias pistons for the pistons, but not sure what kind of rods to source out?
who makes rb20 rods if anyone?
also i plan on working the rb20's head a bit, if anything to just clean it up and perhaps enlarge the valves a bit to aid in airflow.
thoughts please!
https://www.sau.com.au/forums/topic/93802-building-a-rb20det/
thoughts please!
err rb30's are single ohc .. :D
hey carl h...i have done pretty much what you want to do. i can say that the arias pistons are great.. haven't had any problems with them...they were nicely made with about 1 - 2 grams difference between the 6... so weight mathcing them was easy....
About the rods i dont know, i used the standard ones...just got them ballanced and weight matched....
in terms of head work i got the head ported and polished with 1mm oversized valves..you will find that ca18 valves are perfect for it..they are 1 mm larger than standard rb20 ones and fit with no trouble...
hope that helps....
Aaron
hope that helps....
Aaron
spot on there sir spot on!
as far as the valves, the standard ca18 valves will fit into the head? and if so 1mm will certianly aid in airflow into the motor.
how much power are you making with standard rods, everyone seems to have gotten in on a betting pool on my car when it comes to the motor's internals......
cheers!
in terms of power i havn't done a power run as yet..i am stil adding bits a pieces and changing things around. it made 138 rwkw before it all and this is auto so would be a bit more if manual.
It goes a sh1t load better since i did all of the stuff...the full potential hasn't been reached yet but from the mods i have done and from what i seen other people get i would say that it would have to be easy over 200rwkw...but it has alot of variables...you could put arias pistons in, other rods , over sized valves etc and still have the same amount of power that you started with or very little more...
it will aid greatly if adding biggger turbos and more boost etc
yes the valves do fit..they are in my car now !!
i guess it comes down to what you want to achieve with the engine on whether it will be worth it and whether it make a worthwhile difference.
And whether to get aftermarket rods.....
what do you want to achieve ???
My first recommendation would be to install the pistons for the RB23/24 kit (but leave the stroke the same). That way, you get a bit of capacity, but better you get a bit of off-boost compression (I think I calculated 0.5 increase in C/R). That gives you 9:1 C/R; considering the racing GT-R's we had in Oz ran 9.2:1 and 1.8bar, I think the RB20 will cope.
DRIFTER - if you stick a head of a larger capacity engine onto a smaller capacity block, you LOSE compression. Apart from the fact that a RB30 head will not fit comfortably on a RB20 block. And why would a single cam head flow better than a twin cam head. I think you are thinking of the RB25DE(T) head onto a RB30 block.
ebola...i am still runnning standard cams...but am running os geiken adj cam gears... waiting for gtr cams to see how they wil go with chipped ecu..there was a big thread about it a while ago....in terms of rev limit i have no idea....but with 20's power almost alwasy drops off after about 6800 - 7000 RPM so.....
Theres also a mass of threads about GTR cams NOT working in RB20 due to the ramp rate being greater compared to the standard 20 cams, and therefore the cars that have had GTR cams installed are struggling to idle. I would investigate those threads before throwing in the GTR sticks.
JK
well on my car i have tomei 260/8.8 cams with greddy gears and a gt30r turbo, so it is a bit laggy but pulls like a cut bastard to redline (8.5k).
i mainly want to build the engine not for outright power but for reliablity, i plan on keeping the car round for another few years and i cant imagine that the stock internals are going to keep up with the 450bhp the car puts out on high boost.
  • 4 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
