Most of the aftermarket rods around will cope with what you want. Argo are a nice rod, a little heavier than others, PAR rods are similar, maybe a little more modern profile. A lot of US Supra guys are running crower rods at over 1000hp. Carrillo are probably the ultimate rod but you will pay for them. I'm fairly sure you can get eagles now for RB30's, I'd have no problem using them either. A lot depends on how much you want to spend, there are other companies that will make them, Pankl make a nice rod but the $ is up there, Pauter make a strange looking + beam rod that many people have used with a lot of success. It all really depends on your budget, the more you spend, the better rod you will get.
can i get some input on forged aftermarket conrods? I-beam vs H-beam, has anybody had experiences with EAGLE, ARGO, REV, PAR, CROWER. The application will be for a 900hp rb26/30. Bad and Good experiences (how much power? and to what revs?) will be greatly appreciated  :)
A little bit to add to;
We have used Carrillo H Beam rods for 950 bhp, with a max of 8,500 rpm. That is using a full billet aluminium block girdle.
Argo make both I Beam and H Beam, we tend to use I Beam as they will tolerate a bit more contact than the H Beam. We are up to 750 bhp and 8,000 rpm with them, not using a block girdle.
We have used Eagle H Beams, mostly in circuit race engines up to 650 bhp. Not had a problem, they service nicely after a full season of racing.
My suggestions, pay the extra and use Carrillos. You will have more than enough other stuff to worry about, so crossing off the rods is a good start.
:) cheers :(
What greg said is on the money whats your budget than we can recommend something for you based on that. A 900hp engine is expensive, I see to many people these days thinking a 700hp engine is the same as a 900-1000 hp engine. Dont just consider the engine parts when building a car like this think down the line like gearbox, driveshafts, diffs the list goes on. Also an engine like that will need a lot of maitnance, ie. pulling it down every few thousand kays and checking bearing and components!!!
I personally dont go much on Carillos and alot of people might shoot me down but here is why. Carillo hasnt changed its design in 20 years, this says to me that they arent doing any continued R and D this is a worry cause no matter how good you make something you can always refine it, people say they got it right the first time well I am not convinced. Secondly I am not questioning their strength or quality of finish or materials they are high quality but their strength comes through the fact the are a very chunky rod and heavier than all others I have had. A six inch Carillo weighs from memory around 710grams, a standard rb30 rod which is basically the same thing is around 630...this is standard. I feel Carillos are great for strength no doubt about their durability but its due to more metal as well, whereas some of the other manufacturers are trying to go lighter through design and developement and keep the same strength as say a carillo. Company's like Pankl and crower impress me as they are constantly testing their stuff to meet higher and higher standards, and their rods look amazing, but you pay for it also!!!!
I used Pauter rods in my engine and are holding 610rwhp without a drama i was told rated at 250hp a rod. They are quite light and have a weird design (+ beam ) thats seems to work well. Brian Pauter (shop owner) told me they make rb30 rods to order. WWW.PAUTER.COM
Edited by R32-GTS
TOP 5 OFF THE SHELF:
PAUTER $around 2k landed
CARILLO $2500+
ARGO $1900
REV $1500
EAGLE $1300
All the rods in this list are good rods that would suite almost any engine combination and be strong enough for anything up to 800hp, also that list is in no particular order and I havent included rods like Crower, oliver and Pankl for example as they arent ready made you have to get them custom made.
TOP 5 (If moneys no object, all custom made)
1) Crower Titanium $5000+
2) Arrow Engineering Titanium $5000+
3) Pauter Titanium $7000+
4) BME Aluminium ( moneys no object you can replace them every 1000ks) $3000+
5) Cunningham Aluminiums $3000+
Edited by Fitzpatrick Speed Works
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
