very blur now.. found just got $50 short,,maybe someone gave me 120 by mistake??........
MY ADDRESS IS
13 KILLALOE PLACE, WATERFORD, WA, 6152,
0402736958 BEN
PLEASE COME AFTER 6,30PM AS I'LL BE IN THE COURIER COMPANY THAT TIME.
AND PLEASE GET THE CASH READY AND SORRY I HAVE NO CHANGE..
AND PLEASE MAKE SURE U COME AND PICK THEM UP BEFORE THURSDAY COZ I'M GOING OVERSEAS TO SEARCH MORE CHEAP PARTS.
https://www.sau.com.au/forums/topic/93885-hid-kits-arrived/
AWESOME !! :cheers:
so how much was the total price including postage? Did it come to 220?
220 - 50 deposit = $170 remaining balence.. this correct?
Oh, and is it okay if i deposit the money into your account via net bank like last time? My frend is going to pick up the kit for me.. and I cant get it in cash.. but i got money in my bank.. So ill deposit the money into your account.. and my frend will pick up his and my kit for me..
Thanks
https://www.sau.com.au/forums/topic/93885-hid-kits-arrived/#findComment-1695867
i had a set of H4's, and a set of H7's, thats $470 + is it $20, or $40 postage?
sorry i didn't received your deposit .so i didn't order yours..
maybe i can put u down to the second run?
sorry about this ..but i really had to confirm everyone...
https://www.sau.com.au/forums/topic/93885-hid-kits-arrived/#findComment-1696034
AWESOME !! :cheers:
Thanks
Hi ..i'll prefer cash could you pls go to the atm and get the cash? coz i'm going overseas this thursday so i won't be able to check up the bank account
https://www.sau.com.au/forums/topic/93885-hid-kits-arrived/#findComment-1696038
hey bankids, correct me if im wrong,
but from the way i read the post, I thought the total cost of the hid kit is $200 and the $20 postage is for anyone who can't pick it up and you would send out the kits for that much????
if it isnt the case I wish I was informed better.
I will be picking the kit for "h3roic5" and myself ok? most likely late wednesday or early thursday! is that ok?
https://www.sau.com.au/forums/topic/93885-hid-kits-arrived/#findComment-1696714
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
