UPDATED 1 JUNE 2007. STAY TUNED FOR SOME MORE ADDITIONS!
Headunit Installation
Virtually identical for all but here's discussion for
R32
R33 - with links to pics
R34 - courtesy of r34gtt.net
Stagea
Wiring up your headunit
Nissan Wiring Harness information - verified as correct by me :D
Need a DIN pocket?
Just head to your local Nissan dealer. Any post-1996 Nissan car (eg N15 Pulsar) will have a DIN pocket that will fit in your Skyline.
Antennas
Jap - Aussie antenna conversion - you need an adaptor. The Aerpro AP348 is $15 from any stockist (Autobarn, etc)
Can't pick up radio on a Japanese headunit?
If your headunit reads on the Japanese FM frequency (~75-90kHz), you'll need a frequency/band expander to compensate. Pick one up from your local car audio store - the Aerpro AP745 costs $19.
That, or get a new headunit :)
Sound Deadening
It's one of the most effective ways to improve the sound in your Skyline! If you're outside your car, knock the body panels and listen for that hollow 'tin can' reverberation. I'd go so far to say that deadening at least part of your front doors is mandatory if you are concerned about decent sound.
https://www.sau.com.au/forums/topic/94069-car-audio/
  • 1 year later...
Speakers
The factory speaker sizes were as follows:
R32 - 4x6" front, 6.5" rear (Plate in front doors will see a 6" in there)
R33 - 6.5" front/rear - mounting depth is approximately 57mm (as measured by me!)
R34 - 6.5" front/rear - deep speakers are not a problem. There are no constraints with mounting like the 33.
6x9s will fit in the back fairly easily, need a spacer.
6x9s will fit in the fronts not so easily (again you'll need a spacer), but still doable.
Predator's spacer template for front R32 speakers
Changing rear speakers in your Cefiro
Changing rear speakers in your R32 (including parcel shelf removal)
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3154957
Subwoofers
Wiring up your subwoofer
There are plenty of ways to wire up a subwoofer, depending on how many subs and amps you have, their configuration, etc. Crutchfield has put together a fantastic guide which shows you how to wire up as many as four subwoofers to your car. Check it out at the following link:
http://www.crutchfield.com/learningcenter/...ers_wiring.html
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3154964
Troubleshooting
Help! I've installed my system and now I get a whining / hissing sound from my speakers!
Wayne Harris has written a fantastic article which covers most types of noise, and contains step by step information on how to isolate the problem in your car. It is a MUST READ if you are trying to troubleshoot. Read the article here: http://www.termpro.com/articles/noise.html
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3154970
  • 8 months later...
Wiring Diagrams (care of Chris Rogers)
Tacho addition:
http://www.apexi-usa.com/pdfWiring/3.pdf
(this is the current RSM diagram - gives speed ,tach,ign wiring off ECU)
R32 - RB20
P23 diagram:N4a
R32 GTR - RB26
P23 diagram N4B
R33 - RB25
P23 Diagram N4C
R34 - P23 also :D
R32 stereo wiring
http://www.installdr.com/Harnesses/Nissan-Wiring.pdf
when following this diagram the black wire on your radio goes to frame! nowhere else.
R33 stereo wiring - SEE R32
R34 Stereo Wiring
use the 2nd diagram. for R33 S2 - use 2nd diagram.
V35/M35 base spec:
2nd diagram. DO NOT attempt this on a BOSE VERSION! it has an ENTIRELY DIFFERENT SETUP and you WILL kill something. cars later than 05 are CANBUS so be VERY careful here.
34 GTR display info inc swapping to non GTR dash.
Here's a good guide for transplanting the MFD into an ER34.
http://flatout.main.jp/driving/parts/bnr34mfd
Here's an excellent guide for transplanting the MFD into an R33
http://www.geocities.jp/yossyi_bcnr33_carbon/inpure/MFD.html
An AV cord to output TV onto the MFD (Clarion part #:855-5430-00)
http://pub.ne.jp/BNR34/?entry_id=89518
MFD pinouts
http://f14.aaa.livedoor.jp/~lindwurm/bnr34/diy/mfd/mfd.htm
PIVOT START BUTTON
http://www.pivotjp.com/download/download-e.html
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3629119
  • 3 months later...
R32 Owners:
If your planning on installing Amps and Subs, something you seriously need to think about is the grounding system in your car.
The standard grounding system in the R32 (I am using a GTR as my reference point) is adequite for a headunit, and for the standard Skyline electrical system, but if you add high powered audio amplifiers, D-class monoblocks, and other hardware, then the stock grounding from the battery will be insufficient to power your gear.
The biggest give-away that you have a grounding problem is that horrible engine noise that you sometimes get through your speakers, this is caused by the Alternator powering your device instead of the power feed coming from the battery.
Electrical Theory:
Basically, Electrical current (against popular thought) actually pushes the electrons FROM the positive terminal or power feed TO the negative terminal or Grounding point. If the grounding point is not up to the demand, then the Positive feed can not push out as much amperage.
If your system is a sh1t-hot system, but you have the stock 8-gauge grounding fromt he battery to chassis to engine block, and your running a 4-guage power feed from the positive terminal to your amp(s), then when the system gets cranking, the system will bottle-neck at the 8-guage battery - chassis ground, and start demanding power from somewhere else that can both feed and ground adequitely.
Guess what, the only other powersource in the car that can possibly meet the demands of your high-end audio gear is your alternator, so the system starts feeding from power from the Alternator as well as the battery, and thus, you have engine noise.
How to fix this problem:
Head to the local Jaycar/JB Hi Fi, Dick Smith Electronics, Etc, and get yourself a car battery terminal that will fit your battery. Next, get yourself either 4-gauge, or even some 0-gauge wire, probably about 2 meters will be sufficient, and your set to start work.
Basically, you need to remove the current grounding from the battery to chassis to engine block, and replace it exactly as it's installed currently, but with the thicker wire.
Remeber, current needs a clean path, so have some sand paper on hand, and where the cable gets grounded to the chassis, clean the metalic area completely until it's beautiful and shiny, then strip back the cable sheith and bolt down the cable (I like to use some clear-coat once this is done, to provide a barrier against oxygen getting into the freshly sanded metal and attracting a rust-spot).
The bitch is grounding to the engine block, but with some patience and time, you will be able to get under the throttle body and undo the current ground and replace.
This will resolve 90% of engine noise from from an R32 GTR's audio setup, if you still have engine noise, you haven't grounded the amplifiers correctly, but that's for another How-to or informational thread.
Thanks.
B.
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3867910
  • 4 weeks later...
  • 2 months later...
  • 4 months later...
  • 2 months later...
  • 1 month later...
  • 1 month later...
  • 3 months later...
i'm sure you can fit an 8" in a good box in the trunk with no problem. i've got room for a box holding two 14"'s in mine and the amp as well--have you got some other mods taking up your trunk space?
with ever increaseing range of flat subs you should be able to purchase a good sounding sub that wont take up much room.
these go fairly well http://kicker.com/compvt_subboxes <--- you can get them pre boxed in 8" 10" and 12" or you can get the subs on there own in the same sizes as well as a 6.5 inch which would need a custom box, or you could mount it in the rear speaker slots.
pioneers version also goes well. http://www.pioneer.com.au/en/Products/Car%...Subwoofers.aspx (scroll down they are there, however i couldnt be botehred to find pre boxed versions but they do exist) these are from a 8' to 12" only as far as i know.
i beleive a few other brands have had a go, but these are the only 2 i have actually heard and seen playing.
so if you like your boot space, these are the way to go.
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-4880065
  • 7 months later...
Thread from the dead.
Regarding subs in an R34, yes there is HEAPS of room wtf are you guys on about lol.
If you have a factory 17" mag instead of a space saver and your no longer using the plywood sheet there is a nice spot on the left hand side (the wider wheel sits up more creating a nice slot either side) that will fit a 12" sub in an average size sub box. (warning don't put a large box there as it may move in the way of the hinge locking the boot shut, but a normal size wont)
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-5238263
  • 2 months later...
2009-2010 R35 GTR Alarm diagram
MODEL YEAR(S) GT-R 2009 -2010 KEY T-HARNESS IMMOBILIZER N/A N/A NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1 PART COLOR LOCATION 12 VOLT CONSTANT GRAY (+) 40 AMP @ BCM, (BLACK, 3-PIN PLUG), PIN 1, NOTE #2 STARTER BROWN (-) @ PUSH-BUTTON IGNITION Switch or BCM, (BLACK, 40-PIN PLUG), PIN 18, NOTE #2 STARTER 2 LT. BLUE (-) @ BCM, (GRAY, 40-PIN PLUG), PIN 21, NOTE #2 IGNITION 1 RED (+) Low Current @ BCM, (BLACK, 40-PIN PLUG), PIN 11, NOTE #2 IGNITION 2 YELLOW (-) @ BCM, (GRAY, 40-PIN PLUG), PIN 16, NOTE #2 IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 ORANGE (+) Low Current @ BCM, (BLACK, 40-PIN PLUG), PIN 31, NOTE #2 ACCESSORY/HEATER BLOWER 2 ORANGE (+) Low Current @ BCM, (BLACK, 40-PIN PLUG), PIN 24, NOTE #2 KEYSENSE N/A PARKING LIGHTS ( - ) N/A PARKING LIGHTS ( + ) RED (+) @ DASH FUSE BOX, (WHITE, 10-PIN PLUG), PIN 8 POWER LOCK PINK (-), TYPE B @ BCM, (GREEN, 40-PIN PLUG), PIN 17, NOTE #2 POWER UNLOCK BROWN (-), TYPE B @ BCM, (GREEN, 40-PIN PLUG), PIN 20, NOTE #2 DOOR TRIGGER GRAY (-) @ BCM, (GREEN, 40-PIN PLUG), PIN 39, NOTE #2 DOMELIGHT SUPERVISION PURPLE (-) @ BCM, (WHITE, 16-PIN PLUG), PIN 16, NOTE #2 TRUNK RELEASE GREEN (-) @ BCM, (GRAY, 40-PIN PLUG), PIN 36, NOTE #2 SLIDING POWER DOOR N/A HORN WHITE (-) @ HORN Switch, (GRAY, 8-PIN PLUG), PIN 8 TACH LT. BLUE (AC) @ POWER STEERING CONTROL UNIT, (WHITE, 12-PIN PLUG), PIN 10, NOTE #3 WAIT TO START LIGHT N/A BRAKE PINK (+) @ BCM, (GREEN, 40-PIN PLUG), PIN 7, NOTE #2 FACTORY ALARM DISARM DISARMS from FACTORY REMOTE ONLY!! ANTI-THEFT NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1 EXTRA INFORMATION NOTE #1: NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, Part # 791 or XK07 (For REMOTE START ONLY) Part # DLPK-CANBUS MULTI (for REMOTE START and DOOR LOCKS) NOTE #2: the BCM (Body Control Module) is located in the PASSENGER KICK PANEL. NOTE #3: the POWER STEERING CONTROL UNIT is located under the PASSENGER DASH, behind the GLOVE BOX.
Edited by sapphiregraphics
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-5356276
    • Whatsapp +35796370243 [email protected] Telegram.@tesgkm L'argent joue un rôle essentiel dans nos vies. Achetez de la fausse monnaie. Elle est nécessaire pour des besoins essentiels comme se nourrir, se loger, se vêtir et se soigner. De plus, elle offre des possibilités d'éducation, de voyage et de développement personnel. La stabilité financière peut réduire le stress et donner la liberté de vivre ses passions. Cependant, il est également important d'acheter de la fausse monnaie. N'oubliez pas que l'argent ne fait pas tout. Achetez de faux billets. Pour les relations, la santé et le bonheur sont tout aussi essentiels. Comment pensez-vous trouver un équilibre entre gagner de l'argent et vivre une vie épanouissante ? Acheter des faux billets en euros Acheter de faux billets Où acheter de la fausse monnaie ? Où acheter de la fausse monnaie fictive ? Où acheter de la fausse monnaie ? Faux billets en euros authentiques Véritables billets en euros à vendre Acheter de la fausse monnaie en ligne Acheter de la fausse monnaie indétectable en ligne Acheter de la fausse monnaie en ligne aux États-Unis Acheter de la vraie fausse monnaie en ligne Acheter de la fausse monnaie en ligne Acheter de fausses balles Où acheter des faux billets Acheter de faux billets en ligne Où acheter de faux billets de 100 dollars Où acheter de faux billets de dollars Où acheter de faux billets de millions de dollars Acheter de faux billets en euros Acheter de faux billets de dollars Comment obtenir de la fausse monnaie ? Faux billets de 20 dollars Vérification des faux billets Acheter des contrefaçons indétectables Argent, Acheter de la fausse monnaie qui semble vraie en ligne, Où puis-je acheter de la fausse monnaie qui semble vraie, Où puis-je me procurer de la fausse monnaie, L'argent est une nécessité ! On en a besoin pour couvrir les dépenses de base comme se nourrir, se loger et se vêtir, mais aussi pour épargner, investir et atteindre des objectifs à long terme. La stabilité financière peut réduire le stress et apporter la tranquillité d'esprit. Que pensez-vous de la planification financière ou de la gestion financière ?
    • Whatsapp+35796370243 Telegram.@tesgkm Geld is een noodzaak! Mensen hebben het nodig om basisuitgaven zoals eten, onderdak en kleding te dekken, maar ook om vals geld te kopen, te sparen, te investeren en langetermijndoelen te bereiken. Financiële stabiliteit kan stress verminderen en gemoedsrust bieden. Wat is jouw mening over financiële planning of geldbeheer? Koop valse bankbiljetten online. Valse eurobiljetten kopen Valse bankbiljetten kopen Waar kan ik vals geld kopen? Waar kan ik vals speelgeld kopen? Waar kan ik vals geld kopen? Echt lijkende valse eurobiljetten Echte eurobiljetten te koop Vals geld online kopen Onzichtbaar vals geld online kopen Vals geld online kopen in de VS Echt vals geld online kopen Vals geld online kopen Nepballen kopen Waar kan ik een vals biljet kopen? Valse biljetten online kopen Waar kan ik een vals biljet van 100 dollar kopen? Waar kan ik valse dollarbiljetten kopen? Waar kan ik valse biljetten van een miljoen dollar kopen? Valse eurobiljetten kopen Valse dollarbiljetten kopen Hoe kom ik aan vals geld? Valse biljetten van 20 dollar Controleren op valse biljetten De aanhoudende crisis is inderdaad zwaar, met veel bedrijven die sluiten, waardoor mensen moeite hebben om rond te komen. Het is een echte uitdaging om voor gezinnen te zorgen en rekeningen te betalen wanneer de inkomstenbronnen slinken. Welke ondersteuning of hulpmiddelen zouden volgens jou het meest nuttig zijn voor de getroffenen?
    • WhatsApp+35796370243 [email protected] Telegram.@Tesgkm Compre dinero falsificado y ayude a las personas de todo el mundo a lograr su objetivo para que tengan una buena vida para que puedan pagar lo que nunca pueden pagar con mi tipo de dinero. Tengo. Haré que tus sueños se hagan realidad, haz que el mundo por delante te respete a tus amigos cercanos que te respeten a tus enemigos y le das la mejor vida para ti y tu familia. comprar bannotes de euro falsificados comprar billetes falsos ¿Dónde puedo comprar dinero falsificado? ¿Dónde puedo comprar dinero de juego falso? donde comprar dinero falsificado Billetes de euro falsos de aspecto real Banknotes euro reales en venta comprar dinero falsificado en línea comprar dinero falsificado indetectable en línea comprar dinero falsificado en línea USA comprar dinero falsificado real en línea comprar dinero falsificado en línea comprar bolas falsas Dónde comprar facturas falsificadas comprar facturas falsas en línea Dónde comprar un billete falso de 100 dólares ¿Dónde puedo comprar billetes de dólar falsos? ¿Dónde puedo comprar billetes falsos de millones de dólares? comprar facturas de euro falsas comprar facturas de dólar falsas Cómo conseguir dinero falsificado Bills falsificados de 20 dólares Comprobando las facturas falsificadas Tener un hogar cómodo puede mejorar en gran medida la calidad de vida. El dinero puede proporcionar los medios para pagar un espacio de vida seguro, seguro y acogedor para usted y sus seres queridos. ¿Qué características o comodidades harían que una casa se sienta como una casa de ensueño para usted?
    • WhatsApp: +35796370243 E-Mail: [email protected] Telegram: @tesgkm Kaufen Sie Falschgeld und helfen Sie Menschen auf der ganzen Welt, ihr Ziel zu erreichen: ein gutes Leben zu führen und sich Dinge zu leisten, die sie sich sonst nie leisten könnten. Mit meinem Geld. Ich habe es. Ich werde Ihre Träume wahr werden lassen, Ihnen die Welt vor Augen führen, dafür sorgen, dass Ihre engen Freunde Sie respektieren, dass Ihre Feinde Sie respektieren und Ihnen und Ihrer Familie das beste Leben ermöglichen. Gefälschte Euro-Banknoten kaufen Gefälschte Banknoten kaufen Wo kann ich Falschgeld kaufen? Wo kann ich gefälschtes Spielgeld kaufen? Wo kann man Falschgeld kaufen? Echte gefälschte Euro-Banknoten Echte Euro-Banknoten kaufen Falschgeld online kaufen Nicht nachweisbares Falschgeld online kaufen Falschgeld online in den USA kaufen Echtes Falschgeld online kaufen Falschgeld online kaufen Gefälschte Bälle kaufen Wo kann man Falschgeld kaufen? Gefälschte Scheine online kaufen Wo kann man gefälschte 100-Dollar-Scheine kaufen? Wo kann man gefälschte Dollarscheine kaufen? Wo kann man gefälschte Millionen-Dollar-Scheine kaufen? Gefälschte Euro-Banknoten kaufen Gefälschte Dollarscheine kaufen Wie man Falschgeld bekommt Gefälschte 20-Dollar-Scheine Auf Falschgeld prüfen Ein gemütliches Zuhause kann die Lebensqualität erheblich verbessern. Mit Geld können Sie sich und Ihren Lieben einen sicheren und gemütlichen Wohnraum leisten. Welche Ausstattungsmerkmale oder Annehmlichkeiten würden ein Haus für Sie zu einem Traumhaus machen?
    • WhatsApp+35796370243 [email protected] Telegram.@Tesgkm Il denaro gioca un ruolo enorme nelle nostre vite. Acquista denaro contraffatto. È necessario per nozioni di base come cibo, riparo, abbigliamento e assistenza sanitaria. Oltre a ciò, offre opportunità di istruzione, viaggi e crescita personale. La stabilità finanziaria può ridurre lo stress e dare alle persone la libertà di perseguire le proprie passioni. Tuttavia, è anche importante acquistare denaro contraffatto, ricorda quei soldi  Non è tutto, compra fatture false. Per le relazioni, la salute e la felicità sono ugualmente vitali. Come pensi che le persone possano trovare un equilibrio tra fare soldi e vivere una vita appagante? Acquista banconote euro contraffatte, Acquista banconote false , Dove posso acquistare denaro contraffatto, dove posso comprare soldi di gioco falsi, dove acquistare denaro contraffatto, Banconote euro contraffatte dall'aspetto reale, Vere banconote euro in vendita, Acquista denaro contraffatto online, Acquista denaro contraffatto non rilevabile online, Acquista denaro contraffatto online USA, Acquista online i soldi contraffatti online, Acquista denaro contraffatto online, comprare palle false, dove acquistare fattura contraffatta, Acquista fatture false online, dove acquistare fattura falsa da 100 dollari, dove posso acquistare fatture false in dollari, dove posso acquistare fatture false da un milione di dollari, comprare fatture euro false, Acquista bollette false in dollari, Come ottenere denaro contraffatto, banconote da 20 dollari contraffatte, Verificare le bollette contraffatte, Acquista denaro contraffatto non rilevabile, Acquista denaro falso che sembra reale online, dove posso acquistare soldi falsi che sembrano reali, dove posso ottenere denaro contraffatto, Il denaro è una necessità! Le persone ne hanno bisogno per coprire le spese di base come cibo, alloggio e abbigliamento, nonché per risparmi, investimenti e raggiungimento di obiettivi a lungo termine. La stabilità finanziaria può ridurre lo stress e fornire tranquillità. Qual è la tua opinione sulla pianificazione finanziaria o sulla gestione del denaro?
