UPDATED 1 JUNE 2007. STAY TUNED FOR SOME MORE ADDITIONS!
Headunit Installation
Virtually identical for all but here's discussion for
R32
R33 - with links to pics
R34 - courtesy of r34gtt.net
Stagea
Wiring up your headunit
Nissan Wiring Harness information - verified as correct by me :D
Need a DIN pocket?
Just head to your local Nissan dealer. Any post-1996 Nissan car (eg N15 Pulsar) will have a DIN pocket that will fit in your Skyline.
Antennas
Jap - Aussie antenna conversion - you need an adaptor. The Aerpro AP348 is $15 from any stockist (Autobarn, etc)
Can't pick up radio on a Japanese headunit?
If your headunit reads on the Japanese FM frequency (~75-90kHz), you'll need a frequency/band expander to compensate. Pick one up from your local car audio store - the Aerpro AP745 costs $19.
That, or get a new headunit :)
Sound Deadening
It's one of the most effective ways to improve the sound in your Skyline! If you're outside your car, knock the body panels and listen for that hollow 'tin can' reverberation. I'd go so far to say that deadening at least part of your front doors is mandatory if you are concerned about decent sound.
https://www.sau.com.au/forums/topic/94069-car-audio/
  • 1 year later...
Speakers
The factory speaker sizes were as follows:
R32 - 4x6" front, 6.5" rear (Plate in front doors will see a 6" in there)
R33 - 6.5" front/rear - mounting depth is approximately 57mm (as measured by me!)
R34 - 6.5" front/rear - deep speakers are not a problem. There are no constraints with mounting like the 33.
6x9s will fit in the back fairly easily, need a spacer.
6x9s will fit in the fronts not so easily (again you'll need a spacer), but still doable.
Predator's spacer template for front R32 speakers
Changing rear speakers in your Cefiro
Changing rear speakers in your R32 (including parcel shelf removal)
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3154957
Subwoofers
Wiring up your subwoofer
There are plenty of ways to wire up a subwoofer, depending on how many subs and amps you have, their configuration, etc. Crutchfield has put together a fantastic guide which shows you how to wire up as many as four subwoofers to your car. Check it out at the following link:
http://www.crutchfield.com/learningcenter/...ers_wiring.html
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3154964
Troubleshooting
Help! I've installed my system and now I get a whining / hissing sound from my speakers!
Wayne Harris has written a fantastic article which covers most types of noise, and contains step by step information on how to isolate the problem in your car. It is a MUST READ if you are trying to troubleshoot. Read the article here: http://www.termpro.com/articles/noise.html
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3154970
  • 8 months later...
Wiring Diagrams (care of Chris Rogers)
Tacho addition:
http://www.apexi-usa.com/pdfWiring/3.pdf
(this is the current RSM diagram - gives speed ,tach,ign wiring off ECU)
R32 - RB20
P23 diagram:N4a
R32 GTR - RB26
P23 diagram N4B
R33 - RB25
P23 Diagram N4C
R34 - P23 also :D
R32 stereo wiring
http://www.installdr.com/Harnesses/Nissan-Wiring.pdf
when following this diagram the black wire on your radio goes to frame! nowhere else.
R33 stereo wiring - SEE R32
R34 Stereo Wiring
use the 2nd diagram. for R33 S2 - use 2nd diagram.
V35/M35 base spec:
2nd diagram. DO NOT attempt this on a BOSE VERSION! it has an ENTIRELY DIFFERENT SETUP and you WILL kill something. cars later than 05 are CANBUS so be VERY careful here.
34 GTR display info inc swapping to non GTR dash.
Here's a good guide for transplanting the MFD into an ER34.
http://flatout.main.jp/driving/parts/bnr34mfd
Here's an excellent guide for transplanting the MFD into an R33
http://www.geocities.jp/yossyi_bcnr33_carbon/inpure/MFD.html
An AV cord to output TV onto the MFD (Clarion part #:855-5430-00)
http://pub.ne.jp/BNR34/?entry_id=89518
MFD pinouts
http://f14.aaa.livedoor.jp/~lindwurm/bnr34/diy/mfd/mfd.htm
PIVOT START BUTTON
http://www.pivotjp.com/download/download-e.html
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3629119
  • 3 months later...
R32 Owners:
If your planning on installing Amps and Subs, something you seriously need to think about is the grounding system in your car.
The standard grounding system in the R32 (I am using a GTR as my reference point) is adequite for a headunit, and for the standard Skyline electrical system, but if you add high powered audio amplifiers, D-class monoblocks, and other hardware, then the stock grounding from the battery will be insufficient to power your gear.
The biggest give-away that you have a grounding problem is that horrible engine noise that you sometimes get through your speakers, this is caused by the Alternator powering your device instead of the power feed coming from the battery.
Electrical Theory:
Basically, Electrical current (against popular thought) actually pushes the electrons FROM the positive terminal or power feed TO the negative terminal or Grounding point. If the grounding point is not up to the demand, then the Positive feed can not push out as much amperage.
If your system is a sh1t-hot system, but you have the stock 8-gauge grounding fromt he battery to chassis to engine block, and your running a 4-guage power feed from the positive terminal to your amp(s), then when the system gets cranking, the system will bottle-neck at the 8-guage battery - chassis ground, and start demanding power from somewhere else that can both feed and ground adequitely.
Guess what, the only other powersource in the car that can possibly meet the demands of your high-end audio gear is your alternator, so the system starts feeding from power from the Alternator as well as the battery, and thus, you have engine noise.
How to fix this problem:
Head to the local Jaycar/JB Hi Fi, Dick Smith Electronics, Etc, and get yourself a car battery terminal that will fit your battery. Next, get yourself either 4-gauge, or even some 0-gauge wire, probably about 2 meters will be sufficient, and your set to start work.
Basically, you need to remove the current grounding from the battery to chassis to engine block, and replace it exactly as it's installed currently, but with the thicker wire.
Remeber, current needs a clean path, so have some sand paper on hand, and where the cable gets grounded to the chassis, clean the metalic area completely until it's beautiful and shiny, then strip back the cable sheith and bolt down the cable (I like to use some clear-coat once this is done, to provide a barrier against oxygen getting into the freshly sanded metal and attracting a rust-spot).
The bitch is grounding to the engine block, but with some patience and time, you will be able to get under the throttle body and undo the current ground and replace.
This will resolve 90% of engine noise from from an R32 GTR's audio setup, if you still have engine noise, you haven't grounded the amplifiers correctly, but that's for another How-to or informational thread.
Thanks.
B.
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3867910
  • 4 weeks later...
  • 2 months later...
  • 4 months later...
  • 2 months later...
  • 1 month later...
  • 1 month later...
  • 3 months later...
i'm sure you can fit an 8" in a good box in the trunk with no problem. i've got room for a box holding two 14"'s in mine and the amp as well--have you got some other mods taking up your trunk space?
with ever increaseing range of flat subs you should be able to purchase a good sounding sub that wont take up much room.
these go fairly well http://kicker.com/compvt_subboxes <--- you can get them pre boxed in 8" 10" and 12" or you can get the subs on there own in the same sizes as well as a 6.5 inch which would need a custom box, or you could mount it in the rear speaker slots.
pioneers version also goes well. http://www.pioneer.com.au/en/Products/Car%...Subwoofers.aspx (scroll down they are there, however i couldnt be botehred to find pre boxed versions but they do exist) these are from a 8' to 12" only as far as i know.
i beleive a few other brands have had a go, but these are the only 2 i have actually heard and seen playing.
so if you like your boot space, these are the way to go.
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-4880065
  • 7 months later...
Thread from the dead.
Regarding subs in an R34, yes there is HEAPS of room wtf are you guys on about lol.
If you have a factory 17" mag instead of a space saver and your no longer using the plywood sheet there is a nice spot on the left hand side (the wider wheel sits up more creating a nice slot either side) that will fit a 12" sub in an average size sub box. (warning don't put a large box there as it may move in the way of the hinge locking the boot shut, but a normal size wont)
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-5238263
  • 2 months later...
2009-2010 R35 GTR Alarm diagram
MODEL YEAR(S) GT-R 2009 -2010 KEY T-HARNESS IMMOBILIZER N/A N/A NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1 PART COLOR LOCATION 12 VOLT CONSTANT GRAY (+) 40 AMP @ BCM, (BLACK, 3-PIN PLUG), PIN 1, NOTE #2 STARTER BROWN (-) @ PUSH-BUTTON IGNITION Switch or BCM, (BLACK, 40-PIN PLUG), PIN 18, NOTE #2 STARTER 2 LT. BLUE (-) @ BCM, (GRAY, 40-PIN PLUG), PIN 21, NOTE #2 IGNITION 1 RED (+) Low Current @ BCM, (BLACK, 40-PIN PLUG), PIN 11, NOTE #2 IGNITION 2 YELLOW (-) @ BCM, (GRAY, 40-PIN PLUG), PIN 16, NOTE #2 IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 ORANGE (+) Low Current @ BCM, (BLACK, 40-PIN PLUG), PIN 31, NOTE #2 ACCESSORY/HEATER BLOWER 2 ORANGE (+) Low Current @ BCM, (BLACK, 40-PIN PLUG), PIN 24, NOTE #2 KEYSENSE N/A PARKING LIGHTS ( - ) N/A PARKING LIGHTS ( + ) RED (+) @ DASH FUSE BOX, (WHITE, 10-PIN PLUG), PIN 8 POWER LOCK PINK (-), TYPE B @ BCM, (GREEN, 40-PIN PLUG), PIN 17, NOTE #2 POWER UNLOCK BROWN (-), TYPE B @ BCM, (GREEN, 40-PIN PLUG), PIN 20, NOTE #2 DOOR TRIGGER GRAY (-) @ BCM, (GREEN, 40-PIN PLUG), PIN 39, NOTE #2 DOMELIGHT SUPERVISION PURPLE (-) @ BCM, (WHITE, 16-PIN PLUG), PIN 16, NOTE #2 TRUNK RELEASE GREEN (-) @ BCM, (GRAY, 40-PIN PLUG), PIN 36, NOTE #2 SLIDING POWER DOOR N/A HORN WHITE (-) @ HORN Switch, (GRAY, 8-PIN PLUG), PIN 8 TACH LT. BLUE (AC) @ POWER STEERING CONTROL UNIT, (WHITE, 12-PIN PLUG), PIN 10, NOTE #3 WAIT TO START LIGHT N/A BRAKE PINK (+) @ BCM, (GREEN, 40-PIN PLUG), PIN 7, NOTE #2 FACTORY ALARM DISARM DISARMS from FACTORY REMOTE ONLY!! ANTI-THEFT NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1 EXTRA INFORMATION NOTE #1: NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, Part # 791 or XK07 (For REMOTE START ONLY) Part # DLPK-CANBUS MULTI (for REMOTE START and DOOR LOCKS) NOTE #2: the BCM (Body Control Module) is located in the PASSENGER KICK PANEL. NOTE #3: the POWER STEERING CONTROL UNIT is located under the PASSENGER DASH, behind the GLOVE BOX.
Edited by sapphiregraphics
https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-5356276
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
