  • Replies 44
Basic Performance Upgrades. Originally supra-speak, but I'm borrowing it. :) Pretty much a shorter way of writing exhaust, filter and boost mods.
http://www.mkiv.com/techarticles/ explains it in detail, as well as their other supra-speak nick names (which is getting a little too involved, I think).
A clutch is about $800 installed, then there is the cost of renting your car out to him for a month (~$1000), and then there are dickhead fees ($5000) in this guys case... so to make it fair, get some bricks (use gloves for fingerprint purposes), and throw them into the bonnets of about 7 cars he has in his yard! Make sure when you approach the dealership at night you wear a balaclava as he might have camera's, and dont drive there in your car. Make sure you also have an aliby...
If the dogs might be an issue, then I have found the easiest way around this is to mix some broken glass from light bulbs into some mince meat, and feed it to them. They will be shitting blood, and will surely die.
If he catches you, tie him up and take him for a drive. Go to a nice gravel road, hold him out the door and drag him along the ground while someone is driving...
Then stop somewhere, strip the pr1ck, and threaten to cut his c0ck off with a machette! At this stage he may offer to fix your car... if he doesn't, ram a stubbie up his arse, and then you and your mates piss all over him. Tell him that you will kill him if he doesn't pay up....
That usually works...
hahhaaa.. yes believe me zahos, those thoughts have run through my mind! I even have an extensive range of weaponry should those urges become somewhat unstable?
:devil2:
  • 7 years later...
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
