  • Replies 106
Cam,
For f#cks sake, don't you have enough stickers, any more and you'll break the land speed record, haha.
Works Auto is in Bentley, is that close enough? Otherwise I can organise to bring them to the plex or something for those that miss out. Don't worry, we'll get you some stickers.
See'ya:burnout:
Hehehe, I personally hate lots of stickers on cars, the other week we had a guy bring in a beutiful blue porche 911 (i cant spell). wanting 'jobsearch.com.au' stickers plastered all over it. Took a fair bit away from the car, but I guess it was worth it for the extra HP
Small ones like the SAU ones are okay though :rolleyes:.
Hi Guys,
Memphis has made the stickers, big thanks to him (yeah!), and we sold a few at the York curise. There are still plenty of each left, and they will be taken and left at Works Auto, to be sold for $2each. As Memphis has managed to recoup his expenses, I thought that all other proceeds raised from the sale of stickers should be given back to SAU to help with running costs.
Works Auto is in Bentley, and the stickers will be there on Monday afternoon for people to collect at there leisure. Please make the effort to buy them, cause they look good and will be supporting the forum.
See'ya:burnout:
Bully,
I think the R.I.C.E sticker actually causes drag, hence the reason none of you guys can do faster than 14s:lol:
I think that a SAU sticker on the rear window would look good, plus the money is going to a good cause.
See'ya:burnout:
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
