hey guys. got a r33 gts-t and every time i check the oil its below the low mark.. i dunno if thats a good sign but im guessing not. i last did a oil change 5k ago and since then i have added 1lt of oil and its still below the low marker. its not blowing smoke from what i can tell. its had this problem for a couple of oil changes now, but seems to be getting worse. any one have any idea's.?
i also think i just blew my turbo but yet to confirm that, it makes an awfull grinding noise in high boost so i guessing its F*!@# This just isn't my month.
Ohh yeah besides the noises and oil it still goes hard.
Any advice on either issue would b great.?
https://www.sau.com.au/forums/topic/94521-where-did-all-my-oil-go/
OK first thing i would do is use my EYES... yes that's right. jack it up and have a look. if you suspect turbo problems, oil pissing out of the turbo/everywhere in that are could be a good indication that a seal has blown etc. oir oil line split... If the engine was burning that much oil i'd say it would run like a bag of shit anyway, but you say it is ok..? but if you wanna check the way i have been told by my foreman is ; hold the revs (neutral) at about 3k back off, quickly stab accelerator again.. iff you have blue smoke you have problems, then i would suggest compression check etc.
Now i'm no albert einstein but i'd say looking for the leak first would be the best way to go... come on guys.
Unless he's a complete idiot, I think he would notice an oil patch of the proportions required and, therefore, mentioned it. For it to lose that much oil in 1000 kms and the cause to be a leak from the turbo or lines it would be dripping on the ground fairly heavily. Not to mention the smoke in the engine bay where the oil would be burning on his turbo housing or blowing back onto the manifold.
But then again...I did take for granted that he would check obvious shit first before posting on here. I have made that mistake of assumption before.
Edited by 3lit3 32
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
