These look really good.
What did we do to deserve these then or is part of the upgrade to the new BB still :huh:
Either way they look cool B)
Edited - the other thing I noticed, under where it has my details, I have a % warn with some blue blocks. Is that only the user who can see their own warnings or do I have this % warn thing for some reason :(
https://www.sau.com.au/forums/topic/94568-new-sau-vic-status-labels/
  • Replies 55
What did we do to deserve these then or is part of the upgrade to the new BB still :)
Edited - the other thing I noticed, under where it has my details, I have a % warn with some blue blocks. Is that only the user who can see their own warnings or do I have this % warn thing for some reason :huh:
They look a lot better than the "U R Ghey if U notice this" that was there before it was implemented...
...er... someone pointed it out to me... <_< >_> :(
Now I just have to wait for my membership to go through... *watches label space*
I can only see my warning blocks, so I guess it's just the user that can see it
What do the blue warning block do anyway? I dont think Ive ever got a warning, and i've got 5 blocks!
Or does it show the amount of authority you have to warn other people?
nah the warning is how much 'warnings' you've personaly got...
so if you talk about something norty you might get like 10% warning.
noone cam see what your warning is though :D
i got me 10% warnings... im winning so far hehe :)
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
