Hey liner's,
What makes an 'M-Spec' an M-spec????? (not and, sorry!!)
Specifically for a 1995 GTSt (my car)..........
Is it the spoilers, skirts, tail fin, trim, performance enhancements...etc?
Can one simply tell by looking at it, smelling or tasting it?
(sorry about the crappy pic, if someone needs a few pics to help me out I will gladly then get off my butt and get them, to help you help me!!!!)
I thankyou in advance!
Mark.
Edited by superspit
https://www.sau.com.au/forums/topic/94624-what-makes-an-m-spec-and-m-spec/
to start with... your car's a "Type M" and not an "M Spec" (M Specs were only R34 GTRs) so that sorta makes this whole thread a little redundant :D
Well, that's me, redundant....I do drive a 95skyline!!!
Ok, to rephrase, what's a 'Type M', and is it any different to other 1995 GTST variants?
And thanks for straightening me out FM!!
Mark.
lights and trim......................dunno about the engine or suspension
All R33 GTS-T are 'Type M', there is no such thing as a non 'Type M' GTS-T. The confusion comes from the R32 GTS-T which came as a standard model or 'Type M' which came with some extras as standard.
i thought the type-m r33's where the ones that came with the sideskirts etc etc ?
And the red grille badge..No mech difference afaik.
It's what they call in the trade an svp (special value pack) good for boosting sales or running out old models to make way for the new model.
PlasticStan,
whys your profile got 'Type-M' in the car bit ?
Because that's what car I've got, along with everyone else with an R33 GTS-T, they are all Type M :D :D
Side skirts, larger front bumper etc, were optional extras available on any R33 GTS-T Type M.
There is apparently a difference. Cause i was lookin at some brochure. There is a ECR33 which is a Type M and non Type M. ER33 usually mean non turbo and the ER33 includes the RB20, but there is a turbo version for the ER33. The ECR33 usually mean turbo, there is a ECR33 which is the 2.5 non turbo, GTS25t and the GTS25t type-M. This was what i gathered from the japanese brochure. So i'm pretty interested to know what's the difference btw a Type M and non Type M. Before i got a skyline, i thought the difference btw the Type M and non Type M is the wheelbase width. Which i don't think is correct after seeing so many. Could it be the difference btw the trims and stuff? Options? EG: Viscous LSD and a normal LSD? I think i'll do a little bit of research after my exams ;)
E = RB25
C = HICAS
R33 = Marshmellows
ER33 is an R33 without HICAS, ECR33 is one with... it dosen't mean that they've got turbos or not. Although you usually had to buy a poverty model (ie N/A) R33 to get no HICAS as standard.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
